BT Test Login
- BT Test Login
BT Test Login
06-11-2011 4:03 PM
I have tried the help pages but couldn't find it.
What are the BT Test Login details for troubleshooting a Plusnet connection.
The first step appears to be
Username: bt_test_user@startup_domain
Password: (leave blank)
and the second step
Username: bt_test_user@ispdomain.com
I got that from https://help.fasthosts.co.uk/app/answers/detail/a_id/1598/~/testing-your-connection-to-bt%27s-radius...
If the above is correct what is put in the second test for username
and the second step
Message 1 of 2
(6,802 Views)
1 REPLY 1
Re: BT Test Login
06-11-2011 4:11 PM
Almost right - the basic test is bt_test@startup_domain - if you are diagnosing connection issues and that connects, you can access http://www.bt.net/digitaldemo/ but nothing else.
The ISP specific test is bt_test_user@ispdomain.com, so for PlusNet it would be bt_test_user@plusdsl.net
If you mean for Test 3 on the BT speed test, AFAIR the user name is speedtest@speedtest_domain
None of these requires a password, although some routers do. If yours does, just use something like "adsl1234" or your own connection password should also work.
Message 2 of 2
(5,788 Views)
