BT Maintenance Work from Midnight
goldenfibre
Seasoned Pro
Fixes: 12
Maintenance Reference: PW242162
Start: 27/08/2014 00:00
Cleared: 27/08/2014 06:00
Duration: 5 Hours 59 Minutes
Message: BT is implementing a one-touch project to upgrade MSE, MSC, IEA, EES and EEA devices at (Leeds Basinghall, Wolverhampton, Chesterfield, Filton, Hamilton Avon, Llantrisant, Newcastle-Upon-Tyne, Sheffield Eldon House). This involves a software upgrade and some hardware changes on the device in a single night under (Program 45 - 7750 Software Upgrade).
Area Codes: 01132 01133 01142 01179 01215 01226 01246 01260 01262 01270 01274 01282 01283 01287 01299 01302 01347 01357 01377 01384 01405 01422 01423 01430 01432 01443 01446 01454 01477 01484 01531 01535 01538 01543 01544 01547 01560 01562 01568 01584 01606 01609 01612 01614 01616 01617 01618 01619 01625 01630 01642 01653 01677 01691 01694 01698 01706 01709 01723 01743 01746 01748 01751 01756 01757 01759 01765 01766 01782 01785 01845 01889 01902 01904 01922 01924 01937 01938 01939 01943 01947 01948 01952 01964 01977 01978 01982 02920
11 REPLIES 11
AndyH
Re: BT Maintenance Work from Midnight
They've been doing this across the country at every 21CN exchange for weeks.
Gel
Aspiring Champion
Fixes: 29
AndyH
EU outage of up to 1Hours 30Minutes.
NorthEasterner
Newcastle can't be in it as our area code which covers entire Newcastle and Sunderland which is 0191...
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
Anotherone
Champion
Fixes: 21
NorthEasterner
No disconnection...
Last disconnection was 20 days ago - according to my BT hub 5
AndyH
Quote from: NorthEasterner
I think it's more that Newcastle is a core node and other exchanges connected to it will be affected.
NorthEasterner
My exchange would be connected to the main Newcastle exchange as it is within the city surroundings.
Again no disconnections so it is not accurate.  Undecided
AndyH
It's accurate - it's just you don't know specifically which exchanges/connections are affected.
Anotherone
Champion
Fixes: 21
@NorthEasterner
You may need to look at your modem/router logs as well to see which rhost you are connected to.
Also note this statement in typical Service Notices  such as http://usertools.plus.net/status/archive/1409039340.htm -
Although these are the areas we have been notified of, due to the nature of the broadband network these outages may affect customers nationwide. There are also a number of smaller exchange works most nights of the week that may cause smaller outages at individual exchanges.
Am I likely to notice the work?
Yes, there's a chance that you may be disconnected from the internet for a period of time during the maintenance window.
And whilst more detailed notices from elsewhere give area codes that may be affected that doesn't mean all exchanges with that code will be.
Also to be clear in case there's any confusion the Disconnection is the PPP Internet session, not the sync (unless they happen to be pulling line cards in your own exchange).
HTH.
goldenfibre
Seasoned Pro
Fixes: 12
Telford area will be maintenance next week
Maintenance Reference: PW243359
Start: 24/09/2014 01:00
Cleared: 24/09/2014 07:00
Duration: 6 Hours
Message: As part of BT?s ongoing broadband platform evolution the following exchange area will be impacted by change (Telford). The work is (MSE migration work, programme number 51, software upgrades and customer migrations) and will result in your customers being hosted on BTs strategic platform solution. There will be one service outage to end users of approximately 120 minutes within the period 01:00 - 07:00.
Area Codes: 01952
