BT Broadband Accelerator socket Free*
- BT Broadband Accelerator socket Free*
28-08-2009 3:16 PM
BT Broadband Accelerator is a new name for the BT-i plate master socket
Go to for more details http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=25075&s_cid=btb_FURL_...
For those who gave me a hard time on this product BT do say that even if you have a new openreach type master socket the new Accelerator socket will help stabilise your connection!
See BT website for more details
I am not sure if you have your landline with Plusnet that you can order one
Puddy
Re: BT Broadband Accelerator socket Free*
28-08-2009 3:22 PM
Quote Order your Broadband Accelerator today and you could typically increase your speed by 1.5Mb.
Important:
* We can only send orders to the address where you have your BT Total Broadband.
28-08-2009 3:24 PM
28-08-2009 3:30 PM
Plusnet users CAN order them!!!
Try it yourself
Puddy
Response (SARAH LOUISE REYNOLDS) - 28/08/2009 01:19 PM
Dear Mr ****,
Thank you for your recent BT Broadband Accelerator order.
We’ve now completed your order and you’ll receive your BT Broadband
Accelerator in the post within the next 7 days.
Your order number is DD******
28-08-2009 3:36 PM
Quote from: itsme Only will improve line speed if there are extensions, so does it only filter the bell wire? Cheaper just to the remove bell wire.
Where did you work for BT as an engineer? You seem to think you know more than them?
Please read the page in full it tells you to fit it to the master socket if BT could make a call out for a broadband fix they would charge the customer £120 then just remove the orange wire and then they could afford the final salary pension scheme.
If the new socket just filtered the orange wire why would BT say it stabilise a broadband connection if you have the new openreach master socket
I belive them not YOU
puddy
puddy
28-08-2009 3:38 PM
28-08-2009 3:40 PM
SW
3Mb FTTC
28-08-2009 3:42 PM
click on I have no extensions which gives this response
Quote Sorry, the BT Broadband Accelerator won't increase your speed as you don't have any phone extension wiring that could be interfering with your broadband connection.
28-08-2009 3:48 PM
Your current phone socket already filters interference. However, the BT Broadband Accelerator may help your speed even if it doesn't increase it.
If you dont have any other sockets BT say as you said wont help but for the rest of us a spend of £1.20 might help increase speed. Most complaints to Plusnet are low download speeds
£1.20 for fix I would go for it as my first port of call then call out BT
puddy
28-08-2009 3:50 PM
28-08-2009 3:52 PM
28-08-2009 3:56 PM
puddy
28-08-2009 3:58 PM
Looks like a BARGAIN.
28-08-2009 4:06 PM
Line Attenuation (Up/Down) [dB]: 4.0 / 3.0
SN Margin (Up/Down) [dB]: 20.0 / 14.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 0
All my BT internal extension had been carried out by BT but £1.20 for a BT i-plate seems very good value to me to see if works if not stick it back on ebay.
puddy
28-08-2009 4:27 PM
Please provide a link in the Help and Support Section where I can do it as my phone and broadband are with Plusnet
Quote from: Jameseh think you should book a BT home visit Jim.
