Asus N66U Users Thread
- Asus N66U Users Thread
Re: Asus N66U Users Thread
29-03-2013 7:39 AM
29-03-2013 8:06 AM
How did you do this? Did you properly disconnect the PPPoE session first before rebooting the Asus router? If you just disconnect the router from the modem, power off the router or do anything else that immediately disconnects the router from the circuit, then the PPP server at the other end of the line doesn't detect that the link has gone down. It takes about 8 minutes for the PPP session to time out before you can log in again.
So I'm guessing you switched off your router and the old PPP session hadn't timed out by the time the Asus was ready to log in again. But by the time you'd connected up the PN router the 8 minute time-out had cleared the "stale" PPP session so the PN router was able to log in immediately.
So probably a problem with Plusnet's PPP timers rather than anything wrong with your Asus router.
29-03-2013 8:24 AM
It as been more the 8mins since i unplug the asus router.
29-03-2013 8:45 AM
29-03-2013 9:02 AM
So if you connect the Asus for 10-15 minutes, and nothing happens then at least you have eliminated the above stated theory. Then you could try few things to ascertain weather the router is kaputt.
29-03-2013 9:21 AM
I can drop my session on the techno router from PN and reconnect again i don't need to wait 10-15mins because its already configured, and so is the asus router so why is it not getting a session with the asus router.
29-03-2013 9:29 AM
29-03-2013 9:31 AM
I don't have a Asus but often find the above necessary when trying a different routers.
29-03-2013 9:37 AM
29-03-2013 9:51 AM
Well thats a pain if i want to reboot the router in the future again i need to set it to default settings each time.
29-03-2013 9:55 AM
29-03-2013 11:34 AM
I've also noticed the time zone is 1 hour infront, i set it to GMT, but i guess its no point messing with the time zone now because clocks go forward this weekend.
29-03-2013 11:37 AM
29-03-2013 12:55 PM
any explanation for this on the new firmware?
29-03-2013 1:06 PM
