Anyone interested 150mb down 35mb up?
- Anyone interested 150mb down 35mb up?
04-09-2011 9:34 AM
http://www22.verizon.com/Residential/Bundles/Landing/fiosinternet_ultimate/fiosinternet_ultimate.htm
They get everything better
I now feel like some donkey in some undeveloped country with my 20 down 1 up
im a laughing stock
Re: Anyone interested 150mb down 35mb up?
04-09-2011 9:37 AM
04-09-2011 9:43 AM
04-09-2011 9:59 AM
04-09-2011 10:21 AM
Mind you, you could get a property which is FTTP (100Mb) and find an ISP that'll let you bond two lines for 200Mb internet cheaper than the US 150Mb service.
When it comes to gaming however, speed isn't the issue, it's ping, try to find servers that are in the UK or Europe for lower pings as an American on 512k will beat you, even if you're on Fibre, if the server is in the US.
04-09-2011 11:12 AM
04-09-2011 1:57 PM
04-09-2011 4:28 PM
04-09-2011 5:15 PM
6 49 ms 52 ms 60 ms 10gigabitethernet1-1.core1.lon1.he.net [195.66.224.21]
7 113 ms 117 ms 127 ms 10gigabitethernet7-4.core1.nyc4.he.net [72.52.92.77]
As you can see when it travels from the UK to the US (New York by the looks of it) the ping doubles, well more than doubles but we'll say doubles. By the time it gets to the East coast which I think is Los Angeles the ping is up to 190 but then:
9 190 ms 186 ms 190 ms pacnet.10gigabitethernet2-3.core1.lax1.he.net [26.218.223.206]
10 296 ms 296 ms 299 ms po15-1-0.cr1.nrt1.asianetcom.net [202.147.0.165]
Going across the pacific adds over 100ms to the ping, luckily FFXI isn't ping heavy like an FPS. If however I were to play TF2 on a JP server I'd probably not rank very high! If anyone on fibre could tracert the same IP (202.67.56.0) they should see similar results to mine.
04-09-2011 10:01 PM
Fibre has forced interleaving which is why those BT Infinity ads saying faster gaming make me laugh
The distance to the server is another major factor ofc...
05-09-2011 12:30 PM
Quote from: Gus Broadband ping has nothing to do with the speed of the connection but how far you are from the exchange and how good the routing is to where ever.
Not totally true. When you do a test ping from the command line the packet size is very small hence the time to transmit the package is less significant that the distance from the server. However as the package size increases the time to transmit the package becomes more significant. This illustrates the point:
C:\Users\John>ping ntp.plus.net
Pinging ntp.plus.net [212.159.13.49] with 32 bytes of data:
Reply from 212.159.13.49: bytes=32 time=13ms TTL=251
Reply from 212.159.13.49: bytes=32 time=16ms TTL=251
Reply from 212.159.13.49: bytes=32 time=15ms TTL=251
Ping statistics for 212.159.13.49:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 13ms, Maximum = 16ms, Average = 15ms
C:\Users\John>ping -l 4096 ntp.plus.net
Pinging ntp.plus.net [212.159.13.49] with 4096 bytes of data:
Reply from 212.159.13.49: bytes=4096 time=67ms TTL=251
Reply from 212.159.13.49: bytes=4096 time=66ms TTL=251
Minimum = 66ms, Maximum = 67ms, Average = 66ms
When gaming the packet size will be larger than first test above (but nowhere near as big as the second), so the line speed will have some effect. Two users an identical distance from the exchange but with different line speeds will see different latency, but probably only a few milliseconds difference. BT's advertising is probably factually correct but very much over exaggerating the benefit.
