Amazingly slow speeds
- Amazingly slow speeds
- « Previous
- 1
- 2
- Next »
Re: Amazingly slow speeds
02-01-2016 4:20 PM
Ok I've tested your line and noticed the main problem you're facing seems to be with high noise levels on your line. I've raised your lines stability level in an effort to counteract this, please reboot your router to see if this has worked. There is a chance that this may not resolve the fault in the long run. My advice would be to raise a fault using the following link:
https://portal.plus.net/apps/kbdfaults
This will take you through some steps that may resolve the problem, if not it will raise the issue to our faults team for further investigation.
02-01-2016 5:01 PM
Has the product change worked correctly?
Kirstykt,
Can you please look at the speed issues thread below and post here all of the requested information.
03-01-2016 3:04 PM
Thanks to evryone for your help.
03-01-2016 11:23 PM
- « Previous
- 1
- 2
- Next »
