ADSL2+ and IP block
shamus
ADSL2+ and IP block
My exchange (Godstone) is due for upgrade to ADSL2+ by the end of March.
If I was to request a move to this would this have any effect on my current package (old PAYG 15GB) & block of 8 IP's?
Many thanks for any info...
Shamus
20 REPLIES 20
jojopillo
Re: ADSL2+ and IP block
No, it's just your connection to the exchange that would change, not the account you have with us Smiley
shamus
Thanks Joanne much appreciated.
shamus
Would you be able to check if my exchange is available to take orders for an ADSL2+ move?
http://www.dslchecker.bt.com/adsl/adslchecker.welcome - kind of implies that it is done....
Many thanks,
Shamus
adamwalker
Fixes: 221
Hi Shamus,
If the BT checkers shows availability then that should enable us to place an order on their systems for you.
I shall try that now and let you know how I get on.
Adam
EDIT: order 1-11321530386 now placed and due to complete on 5/4/12 Smiley
 Adam Walker
shamus
Adam - You are a star
Many thanks,
Shamus
P.s how do you know what my Plusnet username is?
adamwalker
Fixes: 221
No problem,
voodoo Cheesy err.. no when you register to the community site the form asks you for your Plusnet account username, if you enter that it links one to the other, hence if I search for "shamus" as a community username on our systems it finds your account.
 Adam Walker
shamus
Any chance my upload could be uncapped please?
many thanks,
Shamus
shamus
I had my upload uncapped and now get the following stats:
  --------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
  Running Mode            : ADSL2+(G.992.5)      State                : SHOWTIME
  DS Actual Rate          : 14678784 bps  US Actual Rate      :  444937 bps
  DS Attainable Rate      : 14756000 bps  US Attainable Rate  :  1156000 bps
  DS Path Mode            :  Interleave    US Path Mode        :  Interleave
  DS Interleave Depth    :      64      US Interleave Depth  :        1
  NE Current Attenuation  :      28 dB    Cur SNR Margin      :        9  dB
  DS actual PSD          :    20. 2 dB    US actual PSD        :    12. 1  dB
  ADSL Firmware Version  : 232201_A
  -------------------------------- ATU-C Info ---------------------------------
  Far Current Attenuation :      12 dB    Far SNR Margin      :      28  dB
  CO ITU Version[0]      : 00004946      CO ITU Version[1]    : 0000544e
  DSLAM CHIPSET VENDOR    : < IFTN >
I was previously syncing at >16000000 downstream. This wouldn't be a problem if my upstream had increased significantly.
As can be seen from the above the upstream sync is virtually unchanged as was previously syncing at 444000. Is this a limitation of my line or is some other cap being applied somewhere that is preventing a higher sync rate on upstream?
Shamus
jelv
Fixes: 10
That doesn't look like it's uncapped!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
shamus
Could one of you kind Plusnet folk please check my account:
https://portal.plus.net/my.html?action=data_transfer_speed indicates Current line speed of 6.5 Mb but am syncing at 14678784bps
Could you also check my upload has been uncapped as I cannot sync higher than 444937bps.
Many thanks,
Shamus
jojopillo
Hi shamus,
Your upload order was placed but it is a 5 working day order. It's due to complete on the 17th. As for your speed I've changed your profile to 12900 to allow for your new BT IP profile. This should take effect shortly.
Jojo Smiley
shamus
Many thanks Jojo... I saw a resync and assumed it was the upload completed  Embarrassed
Shamus
jojopillo
HI Shamus,
would you like me to see if I can cancel the current order, in which case I'll be able to place it manually and get it complete in 24 hours, save you waiting until next week?
Jojo Smiley
shamus
That would be fantastic if you could.
Shamus
