ADSL to ADSL2
- ADSL to ADSL2
ADSL to ADSL2
31-10-2011 5:32 PM
I was upgraded to ADSL2 on the 17th (so 14 days ago) and i havent seen any real speed increase.
Is this normal should i be getting more?
My router stats are
ADSL
Type Interleave Path
Status SHOWTIME
Downstream/Upstream
Data rate(Kbps) 17595Kb/ 440Kb
Noise Margin 5/ 29
Output power(dBm) 126/ 200
Attenuation(dB) 28/ 9
Bt speedchecker gives
1. Best Effort Test: -provides background information.
Download Speed
5908 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 5908 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :17594 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
Upload Speed
345 Kbps
0 Kbps 440 Kbps
>Upload speed achieved during the test was - 345 Kbps
Upstream Rate IP profile on your line is - 440 Kbps
My router stats are
ADSL
Status SHOWTIME
Downstream/Upstream
Noise Margin 5/ 29
Download Speed
5908 Kbps
0 Kbps 7150 Kbps
Upload Speed
345 Kbps
0 Kbps 440 Kbps
Message 1 of 3
(791 Views)
2 REPLIES 2
Re: ADSL to ADSL2
31-10-2011 6:11 PM
I've tested your line (this may have caused a brief disconnection so apologies) and there is an difference in the multiple IP profiles BTW use on your line.
I've raised a fault for you which should correct the issue fairly promptly (24-72 hours).
Regards,
Martin
Regards,
Martin
Message 2 of 3
(359 Views)
Re: ADSL to ADSL2
31-10-2011 6:20 PM
Great. Thank you very much.
Message 3 of 3
(359 Views)
