A Few Questions about upload
- A Few Questions about upload
28-01-2012 1:18 AM
Re: A Few Questions about upload
28-01-2012 1:21 AM
Details here.
28-01-2012 8:44 AM
check your exchange here http://www.samknows.com/broadband/exchange_searchhttp://www.samknows.com/broadband/exchange_search
or here https://www.btwholesale.com/includes/adsl/main.html
as you say you get 600 upload I assume you are on 21 cn as the limit on adsl is 480
28-01-2012 8:57 AM
Quote from: Jaggies On an up to 8Mb connection the only way to increase your speed is to pay extra for Max Premium.
Details here.
i already have max premium and its a 8mb exchanage
28-01-2012 9:03 AM
28-01-2012 12:15 PM
28-01-2012 12:18 PM
28-01-2012 5:10 PM
Quote from: itsme Is the upload speed the problem? I would have thought it would be more likely a LAN problem.
ill post my router stats in a moment, it isnt a LAN problem my sync speed is 0.832 for my upload i think ill post it im shure my home network is fine ive had my fiend who works with it check it all up. im not on 21cn network, although all my local bt manwhole covers have got around noting to widen them and dots next to every houses external wires on my street, although there is no update on www.samknows.com about my exchange, which is Cawood btw if anyone else knows another way of checking when updates are due, ive tried on bt wholesale and samknows which are mentioned above. thanks
System Up Time 311:36:39
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 4225 4181 0 6279 13740 00:04:51
LAN 10M/100M 8185306 8958941 0 2416 1584 311:36:35
WLAN 11M/54M/300M 0 0 0 0 0 311:36:05
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 832 kbps
Line Attenuation 15.0 db 6.5 db
Noise Margin 8.7 db 10.0 db
28-01-2012 5:23 PM
30-01-2012 1:55 AM
31-01-2012 11:27 AM
Might be worth using something like inSSIDer to see if it's worth changing the wireless channel you're on and maybe get a better reception.
Jojo
