Help with testing broadband connection
- Help with testing broadband connection
27-02-2011 5:41 PM
I've been experiencing drop-outs and slow speeds for most of this month. It began when my BT landline became unusable - I completely lost phone and broadband connectivity.
I raised a fault with BT who said there was a problem in the exchange and (supposedly) fixed it within the week.
The fault came back soon after and I once more had to go through the process of getting BT to fix it - which they have (again supposedly) done.
My connection is still very slow and prone to drop-outs, and it seems obvious that this is connected with the BT line/exchange problem.
There doesn't seem to be any obvious way to report something like this to Plusnet without going through the somewhat tortuous automated fault finding process and buying a new router (in order to eliminate the current router as a cause).
This seems to put most of the onus for fixing faults on the customer.
When I asked a 'question'/raised a ticket the reply basically boiled down to Plusnet having no control over physical connection problems within the BT system.
Having just 'downgraded' my account from the over-priced 'Broadband Your Way Option 2' to the (theoretically) superior but cheaper Broadband Extra, I wonder if I've done the right thing - maybe I should have switched straight to BT who - it seems - are ultimately responsible for the majrity of broadband problems?
Re: Plusnet provides the worst customer service that I have ever experienced!
27-02-2011 6:14 PM
Unless you raise a fault using the fault wizard then Plusnet cannot help
Finally you are confusing BT retail who supply your phone connection and BT Openreach who are supposed to fix the problems
If there is a phone problem and a broadband problem then the phone problem must be fixed first as there can't be two faults open at the same time and a phone fault always takes priority.
27-02-2011 6:33 PM
Quote Unless you raise a fault using the fault wizard then Plusnet cannot help
So it seems - but it would be nice if these problems could be addressed through something other than a rigid automated system.
I don't recall plusnet being so dependent on automated fault reporting in the old days.
Quote If there is a phone problem and a broadband problem then the phone problem must be fixed first as there can't be two faults open at the same time and a phone fault always takes priority
The phone line problem was supposedly fixed, but it seems too much a coincidence that my broadband problems began at the same time and have persisted since.
BT ( or at least, a bot on BT's website) already conceded that the line fault was due to a problem in their system.
As you must know, getting through to an informed human being at BT is extremely difficult and if the phone itself is working, it's virtually impossible to report any sort of other line fault.
It's a long time since I've had a major broadband connection problem and I'd forgotten how frustrating it can be trying to get someone to to do anything about it.
27-02-2011 6:46 PM
Posts split off as it has nothing to do with the original thread and moved to the correct board
27-02-2011 7:56 PM
27-02-2011 9:30 PM
Quote from: Oldjim The fault procedure involves a series of automated line tests carried out by Plusnet and unless you carry it out the fault will not be sorted
Yes I understand that.
I've been with Plusnet for years but I don't recall the test process in the past refusing to go any further unless you agree to trying a different router.
Not many of us will have spare routers lying around and who's to say that the spare router isn't faulty?
In my case I'm 90% sure the router (Voyager 2110 with wireless currently disabled) is OK as it was working perfectly before the line fault began.
I'd be grateful if anyone can throw some light on these figures from my router:
I just ran the diagnostic test and the results state:
Test the connection to your local network
Test your Ethernet Connection: PASS
Test your Wireless Connection: DOWN
Test the connection to your ADSL service provider
Test ADSL Synchronization: PASS
Test ATM OAM F5 segment ping: FAIL
Test ATM OAM F5 end-to-end ping: FAIL
Test the connection to your Internet service provider
Test PPP server connection: PASS
Test authentication with ISP: PASS
Test the assigned IP address: PASS
Ping default gateway: PASS
Broadband Line Status
Line Mode ADSL2+ Line State Show Time
Latency Type Interleave Line Up Time 00:03:13:23
Line Coding Trellis On Line Up Count 2
Statistics Downstream Upstream
Line Rate 3023 Kbps 440 Kbps
Noise Margin 16.7 dB 24.5 dB
Line Attenuation 43.0 dB 18.7 dB
Output Power 0.0 dBm 12.9 dBm
I'm not sure exactly what this means, but mybroadbandspeed.co.uk reports my speeds as:
483 kbps (60.4kB/s) 370 kbps (46.3kB/s)
27-02-2011 9:39 PM
The point where it wants a different router as I recall is where an engineer is going to be sent.
If he comes and finds that it was your router - a charge of £140 approx lands on your doormat
What does this say for current line speed https://portal.plus.net/my.html?action=data_transfer_speed
27-02-2011 9:48 PM
Quote from: Oldjim where an engineer is going to be sent.
In all of the (several) past problems I've had with phone line faults and internet connectivity, I have never once had an engineer call!
I've never even managed to get through to one via BT's labyrinthine call centre.
Problems have always turned out to be located at the exchange or somewhere between the exchange and the house.
Re: Help with testing broadband connection
27-02-2011 9:53 PM
Estimated line speed:
2.0Mb (This may vary between 1.5Mb and 5.5Mb) - Checked on 2011-02-14 02:04:24
Current line speed:
2.5 Mb
Well that line speed is a lot faster than online speedtests have shown today (anywhere between 300Kb and 800Kb).
Previous to the phone line fault I was averaging around 5.5 Mb with few dropouts..
27-02-2011 9:59 PM
I had at least 3 or 4 visits when they were trying to fix my problem (they didn't) and eventually the source was found to be in the cabinet in the exchange as it was fixed when I moved from 20CN to 21CN
The current line speed matches your sync speed but the problem is that your default noise margin has bounced up to 15dB because of the earlier problems and won't drop for ages unless interfered with.
You will need to show that your line is stable for a few days and then one of the Digital Care Team will probably be able to get it reset to 6dB. Alternatively your line has been banded and if so that is easily fixed by a Digital Care Team member
It should be the same but can you run the BT speedtest - we really only need to see the IP profile
Just to add - your line speed has nothing to do with the speed of posting or modifying on this forum. I found it no slower when I exceeded my usage allowance and was limited to 128kbps. It is just that the forum is always bloody slow
27-02-2011 10:08 PM
Presumably there's no way to get the noise margin reset without going through the fault reporting wizard?
27-02-2011 10:14 PM
Completing the fault test does help with diagnosing the problem - since you don't have a spare router to try you can opt to continue (and enter "no spare" as the reason). If the faults team feel trying an alternative router is essential I expect they would offer to lend one. They are most unlikely to request a (potentially costly) engineer visit without that being tried.
27-02-2011 11:19 PM
28-02-2011 11:46 AM
Because of the problems you've had the line has been banded, which means that it won't sync above a certain rate. If you think the line fault has been resolved and you can plug into the test socket (if you're not in it at the moment) then I will get the banding removed and we can see what that yields.
Jojo
28-02-2011 1:48 PM
I temporarily plugged the router into the test socket late last night and got these stats (via the wireless connection):
[apologies for the wonky formatting]
System Up Time 00:00:13:07
ADSL Speed (DS/US) 3023/440 Kbps
Latency Type Interleave Line Up Time 00:00:14:07
Noise Margin 22.7 dB 25.5 dB
Line Attenuation 43.0 dB 18.6 dB
Output Power 0.0 dBm 12.8 dBm
Traffic Statistics
Tx packets/Errors Rx packets/Errors
Tx bytes/Drops Rx bytes/Drops
Ethernet 3212/0 3178/0
2482513/0 747830/0
Wireless 299/0 206/0
77190/0 33896/0
WAN 2230/0 2054/0
676848/0 2219472/0
Also, when I tested the speed via mybroadbandspeed.co.uk earlier today the downspeed was just 386 kbps (48.3kB/s)
