Usenet speeds after midnight close to 0 kb/s
- Usenet speeds after midnight close to 0 kb/s
16-01-2010 1:18 AM
Hi
Well I think the subject says it all.
It is now 1:15 and since just before midnight my usenet speed is very close to 0 kb/s literally. Given that it is off peak I would expect something better. I can download via http at my line rate so it strikes me as if something is up with the traffic management. Could someone from PlusNET take a look (not now, in the morning will be fine!)
James
Message 1 of 4
(1,188 Views)
3 REPLIES 3
Re: Usenet speeds after midnight close to 0 kb/s
16-01-2010 12:11 PM
It midnight a lot of users kick off their free overnight downloads so the system takes a big hit for an hour or so. As Usenet is the at lowest priority that is obviously going to take the biggest hit.
Message 2 of 4
(547 Views)
16-01-2010 12:15 PM
It's the same on Pro though which it shouldn't be, you expect a drop between 12-12.30 but after that ti should buck up it not the case now, I was lucky to see anything up to 2mbps last night and that was after 1am had to shuffle gateways and even that wasn't much better, I still think that capacity is suffering as it's going at full rate now
Message 3 of 4
(547 Views)
16-01-2010 4:09 PM
Quote from: jelv It midnight a lot of users kick off their free overnight downloads so the system takes a big hit for an hour or so. As Usenet is the at lowest priority that is obviously going to take the biggest hit.
I have no problem with usenet having a lower priority but I was literally getting close to 0 kb/s last night and this only improved to about 8 kb/s at 2am. Couldn't the priorities be rejigged so that usenet speeds are half way decent rather then unusable?
James
Message 4 of 4
(547 Views)
