Sunday 22nd November 2009Login | Register | Help
Pages: [1]
Changing passwords breaks Wordpress/SMF integration
  • Kelly
  • Plusnet Staff
  • View Profile
« on 04/04/2007, 13:41 »
If you attempt to change your password in either system, they aren't updating each other which breaks the whole integration process.
Plusnet: Head of Platform and Operations
Logged
  • Kelly
  • Plusnet Staff
  • View Profile
« Reply #1 on 04/04/2007, 16:32 »
Colin is working on this now.
Logged
  • Kelly
  • Plusnet Staff
  • View Profile
« Reply #2 on 04/04/2007, 18:14 »
Stopped for a bit on this.  Not proving a simple fix.
Logged
« Reply #3 on 11/05/2007, 16:36 »
Mostly completed at http://community.plus.net/forum/password.php - just need to complete one other bit that I onlty discovered this morning.
Cheers
Colin
Kind Regards,
Colin Ogilvie
Plusnet Application Developer (until June 12th 2009)
Get next generation speeds - Join the ADSL2+ trial!
Logged
« Reply #4 on 15/05/2007, 11:41 »
Right, other change done. As far as I'm concerned, this is now resolved Cheesy
Kind Regards,
Colin Ogilvie
Logged
  • jelv
  • Bright Spark
  • View Profile
« Reply #5 on 15/05/2007, 14:25 »
Worth noting that to get my Wordpress & SMF passwords back in sync I had to change password again, but having done that it now seems OK.
Should we still be seeing the login form with the double fields still?
[attachment deleted by admin]
jelv
Plusnet chatroom: /server usertools.plus.net   /join #usertools
Plusnet Unlimited is not without limits
Logged
« Reply #6 on 15/05/2007, 17:40 »
Yes, because they have nothing to do with Changing passwords ;-)
File it as a bug if there isn't already one.
Kind Regards,
Colin Ogilvie
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
