Phone not working but Broadband OK. Is this an exchange fault?
- Home Phone
- Phone not working but Broadband OK. Is this an exc...
25-01-2015 12:07 PM
Does this suggest an exchange fault rather than a line fault, as it's the same two wires for both services?
ITV Player was buffering a lot yesterday evening around 9 - 10pm. Maybe this was a sign of things to come.
I've reported the fault to Plusnet (98262273 at 10:12 this morning). What are the usual response times for these sort of faults?
I have read some shocking reports of really bad communication problems between Plusnet and BT.
Re: Phone not working but Broadband OK. Is this an exchange fault?
25-01-2015 3:08 PM
Quote from: burrowsp This morning, I get no dial tone from the test socket on the master socket but my Broadband works fine (when master socket faceplate back on).
No, not necessarily. Since DSL will work on one wire, albeit at a reduced rate, whereas the phone requires both.
Quote ITV Player was buffering a lot yesterday evening around 9 - 10pm.
And probably why you're experience buffering
25-01-2015 5:05 PM
25-01-2015 5:50 PM
The support guy did a line test which came back:
Test Result: Fail - Fault located at customer apparatus (appointment required)
Description: LOOP CONDITION DETECTED (UNPLUG ALL END USER EQUIP and RE-TEST)
So, would my Broadband work fine if there was a loop on the phone line?
As I mentioned previously a corded phone plugged into the test socket on the Master socket still gave no dial tone.
26-01-2015 10:03 AM
It looks like you've spoke with us again and an appointment is booked in for Thursday between 1pm and 6pm.
With the nature of this fault, we have had reports of the broadband being fine, and others stating that it's not working. It looks like your connection has remained up, unless you can suggest otherwise?
26-01-2015 10:45 AM
Yes, I have the BT Engineer coming on Thursday.
I have just finished some testing this morning and have added the following update to the case reference:
"I have tested the line from the BT provided termination block on the outside wall of my house. No -50v DC seen on dropwire towards the DP on the nearby telephone pole i.e. towards the telephone exchange, away from my house. I do see a high resistance short circuit also in that direction so it does appear that the fault is somewhere on BT's line plant.
Engineer visit already booked for between 1pm and 6pm Thursday 29/01/2015 so I shall await their visit."
Hope this is of some help.
26-01-2015 10:46 AM
26-01-2015 10:46 AM
26-01-2015 11:02 AM
26-01-2015 12:15 PM
Yes, it's a bonus that the broadband still works, even though there appears to be a short circuit on the line, albeit high resistance.
26-01-2015 12:18 PM
26-01-2015 12:47 PM
A full short circuit would be where the two wires on the phone line were making full contact e.g. fully connected together somewhere. On a meter this would read zero resistance or 0 ohms.
A partial or high resistance short circuit is where there is some form of contact between the two wires but it has some resistance e.g. damp, corrosion, underground cable breaking down etc...
I cannot remember what the reading was on my meter but it had to be on the 20kohm or 200kohm scale before I saw the short circuit, which therefore had a high resistance.
26-01-2015 2:57 PM
26-01-2015 5:14 PM
26-01-2015 5:23 PM
"Definition
A short circuit is an abnormal connection between two nodes of an electric circuit intended to be at different voltages. This results in an excessive electric current (overcurrent) limited only by the Thévenin equivalent resistance of the rest of the network and potentially causes circuit damage, overheating, fire or explosion. Although usually the result of a fault, there are cases where short circuits are caused intentionally, for example, for the purpose of voltage-sensing crowbar circuit protectors.
In circuit analysis, a short circuit is a connection between two nodes that forces them to be at the same voltage. In an ideal short circuit, this means there is no resistance and no voltage drop across the short. In real circuits, the result is a connection with almost no resistance. In such a case, the current is limited by the rest of the circuit."
Again, I have no problem with your definition. It is just terminology used in the industry.
- Home Phone
