Help needed..anyone?
- Help needed..anyone?
31-01-2013 11:36 PM
Re: Help needed..anyone?
01-02-2013 12:09 AM
Unfortunately the Plusnet Current Line speed can lag behind the BT IP profile because the Delta Report that the BT systems are supposed to send to Plusnet for this can sometime take 72hours or so ::), and manual intervention is required. DCT should be able to do this tomorrow if needed/appropriate.
01-02-2013 12:30 AM
01-02-2013 6:07 AM
In may or june last year all most of my neighbours started to get letters from bt and would they like something called fast speed fibre internet
funny I thought why haven't I been asked ?
Spoke to plusnett and they did there best and got the answer sorry mate your not connected to the fttc cabinet (whats that I thought) but direct to the exchange
After a lot of research done on forums and good old google I found I am not the only one with this problem
This is where my life started to take a turn for the worse and the OCD started about getting Fibre
moving on
I was having speed problems with my connection only getting 0.5 mbs download speed so got to know the helpful team in faults very well and they fought on my behalf and got me a steady 2.2mbs after a three month battle with openreach
they suggested lets put a order in for a new line and we will see if we can it connected to a fttc cabinet
this was done after another three month saga with bt but full marks to the plus net team they kept on at bt on my behalf
Sadly we are still waiting fo bt to update there records so I can join the lucky people with Fibre Broadband
So here I am at 05.30am with my OCD on a forum
So to answer your question fastconnection your not the only one
Sorry if this makes no sense to anyone
01-02-2013 7:49 AM
...until you discover how to unlock the modem and install graphing scripts.
01-02-2013 11:34 AM
I had a dream the other night...The Internet was just like the mains/gas supplies....When I plugged in my toaster,it just worked. When I turned on my Gas fire,it just worked,and when I went on the internet,it just worked...then I woke up....and all the stats came flooding back.....Im sure there must be a cure...somewhere....I'd call for a counsellor but he might turn up between 8 and 1 on a day that ive said I'm out.
Seriously, despite all the moans I really Do think that Plusnet are genuinely trying to do a good Job and if you look at some of the other suppliers forums all told ,plusnet are bettter. Its the BT openreach and install teams that cause most of the problems and this will let them down. I sincerely hope they get this part of their business sorted,,for our sake and for theirs.
all the best!
01-02-2013 12:05 PM
Edit: See...I've just fired up Routerstats
01-02-2013 2:08 PM
01-02-2013 2:13 PM
just turn it on and off you go
simple
if only
glad to see you still have your sense of humour
01-02-2013 4:37 PM
Estimated line speed:
40Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-31 19:50:14
Current line speed:
77.4 Mb
Routerstats hmmm will take a look
01-02-2013 5:45 PM
01-02-2013 10:58 PM
The OCD does wear off a bit after a while.
Sorry got to go and check my errors
01-02-2013 11:26 PM
They are excellent, but I like reading the log file :-[.
Quote from: fastconnection Blimey..graphing scripts..thats a new one to me..ill have to look that up now! Ahhhhh! Help..
I've got one of those thingies from British Gas, (we have Dual Fuel from them) which is a weak attempt at a Smart Meter. You clip a sensor round the mains cable into the meter and a wireless display box somewhere convenient, and a little speedo-graph goes up and down on it as electrical items are turned on and off. With a lot of effort you can key in the price and last year's consumption and it gives you a ribbon graph as well showing how you are doing during each day against budgeted usage for the month.
Quote I had a dream the other night...The Internet was just like the mains/gas supplies....When I plugged in my toaster,it just worked.
Syouper! Enjoyyyy!!
01-02-2013 11:44 PM
01-02-2013 11:58 PM
