Stuck Profile
nadger
Stuck Profile
For months my profile has been 7.1mb despite sync speeds that should have given a higher profile.
From btspeedtester
Your DSL Connection Rate :10360 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 9139 Kbps
Albeit it's not causing me any problems it does mean that this months ofcom/samknows figure will be low.
4 REPLIES 4
adamwalker
Fixes: 221
Re: Stuck Profile
I've just moved the profile up a notch to 7150 from 7000 from this end. However I'd expect better than that for a downstream sync 10360. Let me know if you'd like me to try an SNR reset as that may lead to some improvement for you.
 Adam Walker
nadger
Re: Stuck Profile
Thanks for looking at it Adam - as you say one would expect a much higher profile in line with bt tester.
Router currently showing
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 20,977 / 11,140
Bandwidth (Up/Down) [kbps/kbps]: 448 / 10,360
Data Transferred (Sent/Received) [GB/MB]: 83.66 / 525.76
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 23.5 / 38.5
SN Margin (Up/Down) [dB]: 22.0 / 3.0
Vendor ID (Local/Remote): TMMB / TSTC
Let's see if there's an automatic improvement  - as I said it doesn't affect my usage but there's another report due this month.
nadger
Re: Stuck Profile
Profile has now improved to 8mb  Smiley
adamwalker
Fixes: 221
Re: Stuck Profile
That's more like it Smiley
 Adam Walker
