changing the packet size to 1472 from the normal 32 bytes in ping plotter also gives the same latency diffrence as below,
Pinging bbc.co.uk [212.58.224.138] with 1472 bytes of data:
Reply from 212.58.224.138: bytes=1472 time=40ms TTL=121
Reply from 212.58.224.138: bytes=1472 time=37ms TTL=121
Pinging bbc.co.uk [212.58.224.138] with 1000 bytes of data:
Reply from 212.58.224.138: bytes=1000 time=31ms TTL=121
Reply from 212.58.224.138: bytes=1000 time=30ms TTL=121
Pinging bbc.co.uk [212.58.224.138] with 500 bytes of data:
Reply from 212.58.224.138: bytes=500 time=24ms TTL=121
Reply from 212.58.224.138: bytes=500 time=23ms TTL=121
Pinging bbc.co.uk [212.58.224.138] with 100 bytes of data:
Reply from 212.58.224.138: bytes=100 time=16ms TTL=121
Reply from 212.58.224.138: bytes=100 time=17ms TTL=121
