Sunday 22nd November 2009Login | Register | Help
Pages: [1]
Ad-Aware V 8.1.0 2010
« on 02/11/2009, 16:00 »
For all who use the free addition of Ad-Aware, are you aware there is a problem with the upgrade from previous editions? The scan stalls a certain point & everything locks up. You can read all about it here http://www.lavasoftsuppor...m/index.php?showforum=176
If you want to download an earlier version you can get it here: www.filehippo.com
Kind regards,
Chrisco
Logged
« Reply #1 on 03/11/2009, 10:42 »
I use Ad Aware but haven't come across this problem.  The latest version that I am using is 8.1.1 though.
Logged
« Reply #2 on 03/11/2009, 10:54 »
Hi there, I'm wondering if it could be an issue with XP as I have been unable to use the new version on my desktop but my daughter's laptop is running Vista & hers is working ok.
At present I've gone back to the Anniversary edition as it works fine for me, I just hope Lavasoft continue to support it until the creases are ironed out of the new version!
Kind regards,
Chrisco
Logged
« Reply #3 on 03/11/2009, 11:33 »
I'm using version 8.1.0 on XP with no problem.
Wake Up and Smell the Coffee!!
Logged
« Reply #4 on 04/11/2009, 19:59 »
if ad-aware causes a few problems just switch to something else -- that's what I did long ago -- it only ever found cookies anyway
I use superantispyware now on my XP -- never had a glitch or stall when running the program
Logged
« Reply #5 on 04/11/2009, 20:34 »
Same as barky here.... use superantispyware... no problems.... also use CCleaner .... they work well together.
Get paid by the government to go on cruises...... Join the Royal Navy
my website ...http://www.nemosphotography.co.uk        my blogsite.....http://nemosphotography.blogspot.com/        my RedBubble site ...http://lumixfz28.redbubble.com/     also
The Peoples Gallery ....http://www.point101.com/peoples_gallery/    (click "Gallery" then "search" then enter  G.Emson)...  also.... http://www.imagekind.com/...69-41e8-bee9-372ac6a99d6a .... .... and for our American Readers....  http://www.americanframe....ch.aspx?keyword=LumixFZ28
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
