Monday 22nd March 2010Login | Register | Help
Pages: [1]
Incorrect links on sub-forum icons
  • jelv
  • Bright Spark
  • View Profile
« on 10/02/2009, 12:49 »
I've realised that I should have reported this as a bug rather than as a suggestion which is why it has been ignored. As I can't report my own post for being in the wrong forum I'll remake it here - perhaps a moderator could remove the post from the Suggestions (Community Site and Forums) please.
On the image attached there are the following links.
under Your Feedback links to http://community.plus.net...?action=unread;board=49.0
under Product / Service Announcements links to http://community.plus.net...p?action=unread;board=2.0
beside Rants and Raves links to http://community.plus.net...index.php/board,47.0.html
beside Testamonials links to http://community.plus.net...index.php/board,46.0.html
The last link should be to http://community.plus.net...?action=unread;board=46.0 (if you click this link you will find it does work as expected)
jelv
12/18 month broadband contracts have been abolished - all Plusnet residential contracts (including for existing users) are now 10 days (however deferred charges such as activation or hardware may have to be paid if you leave within a year)
Plusnet chatroom: /server usertools.plus.net   /join #usertools
Plusnet Unlimited is not without limits
Logged
  • Oldjim
  • Forum Moderator
  • View Profile
« Reply #1 on 10/02/2009, 12:54 »
Original post removed as requested.
For the future a PM to the mods makes itt much easier
Jurassic Coast
Dorset Area Ramblers
Jim
Logged
  • jelv
  • Bright Spark
  • View Profile
« Reply #2 on 18/03/2009, 15:45 »
Is anyone from Plusnet looking at this forum? It's a month since I posted this topic.
jelv
Logged
« Reply #3 on 18/03/2009, 16:32 »
Hi jelv,
I've added this problem into PUGIT as PUGIT 436.
It may not expedite the resolution, but it should make it easier to search for Cheesy
Logged
  • jelv
  • Bright Spark
  • View Profile
« Reply #4 on 24/04/2009, 15:38 »
Is anybody from Plusnet going to respond to this topic or the PUGIT item?
jelv
Logged
  • Chris
  • Plusnet Staff
  • View Profile
« Reply #5 on 24/04/2009, 15:44 »
So from what I can gather, the problem is that the image next to the subforum name doesn't link to unread posts whereas the image next to the main forum does?
Having a quick look around, it looks like this is the normal behaviour of SMF there doesn't seem to be an option to change where it links to.
« Last Edit: 24/04/2009, 15:47 by Chris »
Chris Parr
Plusnet Support Team
Service Status :: RSS :: Email
twitter / plusnet
Logged
  • jelv
  • Bright Spark
  • View Profile
« Reply #6 on 24/04/2009, 16:03 »
Something has been done to this forum to make it display the standard or New small sub-forum icon - having code to display the appropriate icon, surely it's behaviour should then be consistent with the large standard/new icons.
Most other forums don't have the small icons so the issue doesn't arise.
jelv
Logged
« Reply #7 on 24/04/2009, 22:55 »
I'll add it to a couple of other things I need to do, hopefully possibly next week.
Kind Regards,
Colin Ogilvie
Plusnet Application Developer (until June 12th 2009)
Get next generation speeds - Join the ADSL2+ trial!
Logged
« Reply #8 on 29/04/2009, 15:13 »
Not this week, but should be next week
Kind Regards,
Colin Ogilvie
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
