Saturday 4th July 2009Login | Register | Help
Pages: [1]
Sky/Netgear DG834GT Router
  • pd
  • View Profile
« on 04/06/2008, 22:03 »
Hi
Does anyone know if the Sky/Netgear DG834GT routers are locked to Sky?
If so, are they un-lockable?
Peter
Peter
Metronet PAYG  2003-2008 ::: Plusnet BBYW2  2008-? :::  Plusnet VoIP help for Asterisk
Logged
  • adiewoo
  • Forum Moderator
  • You see, this is a Kamikaze mission!
  • View Profile
« Reply #1 on 04/06/2008, 22:23 »
Yes they are locked to Sky and I believe you can un-lock them with a firmware flash - but as usual at your own risk
Have a look at http://www.skyuser.co.uk/...-got-my-sky-password.html
« Last Edit: 04/06/2008, 22:25 by adiewoo »
Adiewoo - Forum Moderator and customer.
plusnet Unlimited - March '09 plusnet Premier Option 1 - August '03 - March '09
PUG IRC - http://usertools.plus.net/irc/ - usertools.plus.net:6667, Channel #Usertools.
Logged
« Reply #2 on 04/06/2008, 22:25 »
Very unlockable indeed!
Google should get you lots of advice on how to do it.
FYI I'm on Be not PN these days and the DG834GT is a favourite for Be's ADSL2+ connections as the chip sets match the Be DSLAM's. Indeed I use one myself (not ex-Sky, but bought long ago and used with PN). Loads of Be users buy cheap ex-Sky routers and re-flash the firmware.  Grin
Logged
  • pd
  • View Profile
« Reply #3 on 04/06/2008, 22:27 »
Cheers adiewoo & HPsauce.  I'll have a search on ebay.
Peter
Peter
Logged
« Reply #4 on 04/06/2008, 22:29 »
£20 is the going rate + £5 delivery.
Why do you want one?
Logged
  • pd
  • View Profile
« Reply #5 on 04/06/2008, 23:37 »
I need the wireless facility which my current router doesn't have.  I do also have a Speedtouch 585v6 but no matter what I do I cannot get it to forward ports properly.  I thought I might have more luck with the Netgear.  From what I've read it seems these are two of the better routers.
Peter
Peter
Logged
« Reply #6 on 05/06/2008, 09:03 »
See here for unlocking: http://www.jjclements.co....ky-router-dg834gt-unlock/
and here for some interesting technical stuff: http://www.beforum.co.uk/showthread.php?t=9449
Logged
  • Bill_M
  • Bright Spark
  • View Profile
« Reply #7 on 05/06/2008, 09:27 »
Indeed i concur its very easy ive done two without any issue but as stated "at your own risk"
Bill
PlusNet Customer
Member of folding@home for Diseases Research on team Plus.net client id: 69874
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
