SJphone on ipaq
- SJphone on ipaq
SJphone on ipaq
30-04-2008 12:33 AM
Hi
I have installed SJ phone on my ipaq as suggested in the post SJ Labs Softphone for Pocket PC, but have the following message SIP:not registered........ NAT/Firewall:Port Restricted Cone NAT. I am connecting to a voyager 2110. How do I get around the firewall?
Many thanks
Colin
Many thanks
Colin
1 REPLY 1
Re: SJphone on ipaq
30-04-2008 8:16 AM
Quote from: colintaylor ...SIP:not registered
I'm sure this is a setup issue. Have you tried SJPhone on a PC/laptop and see if this works?
Quote from: colintaylor ...NAT/Firewall:Port Restricted Cone NAT.
I think this is a normal message when connecting via a router. I'm at work at the moment so can't check my setup.
Here is some setup information. It's for Voipfone so you will have to substitute Plusnet's details where appropriate.
http://www.voipfoneuserforum.com/about246.html
