File permission problems on ccgi
- Everything else
- File permission problems on ccgi
06-03-2008 10:18 AM
I've installed a TWiki on the cgi server, but I'm having problems with the session files.
These are initially created with me as the owner and cgiusers as the group with the following permissions:
-rw-r--r--
This seems to cause a problem, since I'm having to chmod the files to rw-rw-r-- or I get an error in TWiki (the world rights don't seem to be the issue, since rw-rw---- is also ok).
Oddly, ---rw---- is also no good, which implies that sometimes I'm trying to update these files under my username, and sometimes via the group.
In addition, occasionally these files are created with a owner/group of nobody/nogroup, but I can't quite work out when and why this happens.
I'm assuming that nobody/nogroup is used when apache creates the files, and userrname/cgiusers when a cgi script creates them.
Anyone got any ideas how I could sort this out? Currently, my only solution has been a crontab that resets the permissions once a minute, but this is obviously an 'orrible kludge, and results in intermittent problems.
Oh, and anyone know why chown and chgrp aren't available? And also why I can't setgid on directories?
UPDATE
I've given up and installed mediawiki (an oldish version, since current needs php5). Much easier.
-rw-r--r--
UPDATE
Message 1 of 2
(1,113 Views)
1 REPLY 1
Re: File permission problems on ccgi
09-03-2008 11:39 PM
Does it not work, when you chmod all to 755 (rwx, r-x, r-x)?
When this works then you can use 750 (rwx, r-x, ---) as well, is my experience, and that is always recommended by the forum moderators.
Message 2 of 2
(306 Views)
- Everything else
