Who forgot to renew the license
Oldjim
Resting Legend
Fixes: 63
35 REPLIES 35
KevinG
Re: Who forgot to renew the license
Given that it hasn't worked properly for years, probably best left to fade away.
Strat
Fixes: 565
A bit different....
Chris
Legend
Fixes: 169
Thanks for flagging up, I've given someone a nudge internally about this to look into.
Fixes: 251
Seems that your 'nudge' must have been 'a firm prod with a sharp stick' cos it looks like it got fixed PDQ!  Wink Cheesy
I looked no further than seeing that the expired licence issue had been resolved!  Embarrassed Embarrassed Embarrassed Wink
bobpullen
Fixes: 330
Still erroring here (ref: 89422).
Oldjim
Resting Legend
Fixes: 63
yup - Strat's error for me also
Is this latency thing a new check as I don't remember seeing it before
Me too, could it be down to the fact that my router doesn't respond to pings?
Oldjim
Resting Legend
Fixes: 63
nope as mine does
bobpullen
Fixes: 330
Quote from: Oldjim
Is this latency thing a new check...
Yes, the underlying software has been upgraded (the version we were running previously is now end of life). AIUI, the box/network links etc. have also been bulked up and the caveat about it being broken removed.
Mal08
Still not working here
wayyoung
Quote from: Mook
AFAIK, the PN Hub One doesn't respond to ICMP on the WAN side so I can't see how this would work?
Tony
SpendLessTime
Fixes: 86
Not working here either, latency test cannot connect to test server.
My router does work with Thinkbroadband Quality Monitor so "Houston we have a problem"
Quote from: misterTony
Tony
I don't use the Plusnet Hub I use proper hardware.  Grin See Sig.
wayyoung
LOL. Unfortunately I get an extra 2.5MB sync using the PN Hub compared to my W9980 so a no brainer for me to be using it, although it is painful!
My point being that it's a tool that PN customers cant use when using their PN supplied routers 😕
Tony
mav:quote
