21CN Profile not updating on Plusnet's systems
Oldjim
Resting Legend
Fixes: 63
Given the fact there there doesn't appear to be a solution in site related to getting the information from the BT systems and using it can I suggest that either
Temporarily remove the Plusnet profile limits - note that virtually no other ISP needs one
Do an automatic profile reset to 88.2% of sync speed for all 21CN users by running a script every 12 or 24 hours or better still when the Plusnet system sees a PPP disconnect/reconnect
Edit - clarified 21CN only
39 REPLIES 39
jelv
Fixes: 10
Re: 21CN Profile not updating on Plusnet's systems
Setting it to 88.2% is not the right thing to do for 20CN users!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Resting Legend
Fixes: 63
Clarified - I was only thinking about 21CN but out of interest what would be the effect of doing it on 20CN which could set the Plusnet profile a bit higher than the BT one
Anotherone
Champion
Fixes: 21
I would have thought the same effect - but open to opinions.
GrahamC
It certainly works OK when the profile moves lower ....  Huh
dfunked
Nah, it took over a week for my plusnet profile to catch up recently (my ip profile went from 3.9 to 2.9, so wasn't exactly an insubstantial drop!)
Oldjim
Resting Legend
Fixes: 63
Due to an unknown line problem yesterday evening I had a number of resyncs at lower speed and yes the Plusnet profile has dropped.
What is the odds that it won't rise again
For information this is what happened - overnight Sunday the computer was in sleep mode so no detailed results
Sun 01 Jul 2012  18:48:07	Rx-Noise=5.8	Tx-Noise=23.0	Rx-Sync=4832	Tx-Sync=448
Sun 01 Jul 2012  18:58:07 Rx-Noise=5.2 Tx-Noise=5.0 Rx-Sync=4480 Tx-Sync=160
Sun 01 Jul 2012  19:08:07 Rx-Noise=5.2 Tx-Noise=5.0 Rx-Sync=4480 Tx-Sync=160
Sun 01 Jul 2012  19:18:07 Rx-Noise=0.7 Tx-Noise=5.0 Rx-Sync=4480 Tx-Sync=160
Sun 01 Jul 2012  19:28:07 Rx-Noise=5.3 Tx-Noise=5.0 Rx-Sync=4448 Tx-Sync=96
Sun 01 Jul 2012  19:38:08 Rx-Noise=5.3 Tx-Noise=5.0 Rx-Sync=4448 Tx-Sync=96
Sun 01 Jul 2012  19:48:08 Rx-Noise=5.2 Tx-Noise=5.0 Rx-Sync=4448 Tx-Sync=96
Sun 01 Jul 2012  19:58:12 Rx-Noise=6.0 Tx-Noise=23.0 Rx-Sync=4704 Tx-Sync=448
Sun 01 Jul 2012  20:09:08 Rx-Noise=6.0 Tx-Noise=23.0 Rx-Sync=4704 Tx-Sync=448
Sun 01 Jul 2012  20:19:08 Rx-Noise=6.1 Tx-Noise=23.0 Rx-Sync=4704 Tx-Sync=448
Sun 01 Jul 2012  20:29:08 Rx-Noise=6.1 Tx-Noise=23.0 Rx-Sync=4704 Tx-Sync=448
Sun 01 Jul 2012  20:39:08 Rx-Noise=6.0 Tx-Noise=23.0 Rx-Sync=4704 Tx-Sync=448
Sun 01 Jul 2012  20:49:08 Rx-Noise=6.0 Tx-Noise=23.0 Rx-Sync=4704 Tx-Sync=448
Sun 01 Jul 2012  20:59:09 Rx-Noise=6.0 Tx-Noise=23.0 Rx-Sync=4704 Tx-Sync=448
Sun 01 Jul 2012  21:09:09 Rx-Noise=5.5 Tx-Noise=5.0 Rx-Sync=4384 Tx-Sync=128
Sun 01 Jul 2012  21:19:09 Rx-Noise=5.3 Tx-Noise=5.0 Rx-Sync=4384 Tx-Sync=128
Sun 01 Jul 2012  21:29:08 Rx-Noise=5.1 Tx-Noise=5.0 Rx-Sync=4384 Tx-Sync=128
Sun 01 Jul 2012  21:39:08 Rx-Noise=5.1 Tx-Noise=5.0 Rx-Sync=4384 Tx-Sync=128
Sun 01 Jul 2012  21:49:09 Rx-Noise=6.9 Tx-Noise=5.0 Rx-Sync=4384 Tx-Sync=128
Sun 01 Jul 2012  21:55:13 Rx-Noise=6.7 Tx-Noise=5.0 Rx-Sync=4384 Tx-Sync=128
<Final resync at 08.40 2 July 2012 after several overnight resyncs - taken from router log>
Mon 02 Jul 2012  09:31:31 Rx-Noise=5.9 Tx-Noise=22.0 Rx-Sync=4800 Tx-Sync=448
<connection now stable>
spraxyt
Resting Legend
Fixes: 75
Quote from: Oldjim
I think the odds on this are an 100% cert without manual intervention. Since the system seems quite capable of automatically reducing the Plusnet Profile when sync speed falls the underlying change mechanism must be working. In my opinion, six months after this changed system went fully into operation is more than enough for users to expect it to work in both directions without needing prompts via forum posts or calls to the CSC.
Of course, perhaps it does normally work (in both directions), but I don't recall any posts in this forum confirming it does.
David
EnglishMohican
I'm not convinced that the system even tries to honour the profile. I recently did a speed test and achieved a download speed well in excess of my profile at the time.
Now - would I have been wiser to keep stum?
RPMozley
Seasoned Pro
Fixes: 16
Quote from: EnglishMohican
Yes  Wink
There are odd occasions when the gateway you're connected to doesn't apply the PN profile for some reason. During that time you can achieve a throughput speed more closer to the BT one.
As for profile updating, in my experience it takes quite some days before any movement in any direction. Sometimes it's over a week out of date.
That's RPM to you!!
Oldjim
Resting Legend
Fixes: 63
As suspected it hasn't increased.
I wonder how long it will be for a Plusnet rep to deign to comment on when they are going to fix it and what plans are in hand, if any, for a temporary fix.
Or even to advise where the problem is - within Plusnet systems or BT's systems
leedavies
The problem is clearly Plusnet's system.  They have no business using a cached and stale IP profile to cap throughput - BT does that using the up-to-date value.  It's plain nuts that Plusnet does this again, and gets it wrong.
OTHER ISPS DON'T DO THIS.
jim:quote
orbrey
Chris has explained why we do this here Smiley
jelv
Fixes: 10
When is the failure to update the profile issue going to be fixed?
There's a good reason why you need your own setting, but what use is that if the setting is frequently wrong?
Presumably you've done some sort of audit such as checking the current line speed of 100 random users against their IP profiles - what sort of percentage of users are affected?
Jaggies
Well, mine certainly isn't updating correctly. I lost my connection in the early hours of Friday morning, so restarted the router, and re-synched at a higher rate.
BT Speedtester shows:
IP Profile for your line is - 15.07 Mbps
Member Centre shows:
Current line speed:
    14.8 Mb
The last time the synch rate dropped, the current line speed went down within a few hours, but I've never had it go up without intervention from the DCT.
