windows doesn`t "see" my Caddy HDD
shutter
Fixes: 65
Re: windows doesn`t "see" my Caddy HDD
Well, Have been through 4 Full Formats and one quick format ... all ended up with "windows was unable to complete the format"... and the files are still on the hdd...
A couple of times I tried to delete the volume, and it crashed my windows laptop.... ( Blue Screen with loads of writing on it !).. re booted and runs ok still... but am not much, if any, further forward...
twocvbloke
If that's the case, try using EaseUS partition manager, never had an issue with that in wiping and reformatting drives... Smiley
http://www.partition-tool.com/
Works well when windows (as usual) fails... Smiley
shutter
Fixes: 65
OK... Thanks for the linky.... have downloaded it... and will give it a go this afternoon... (going out now ! ! )...
Wink
VileReynard
Fixes: 20
That's windows for you.
shutter
Fixes: 65
Totally ignoring post number 18....  and  treating it with the contempt it deserves... I shall move on....
@2cv    hmm doesn`t "actually" do anything.... unless it is Paid For....
EaseUS Partition Master Trial Edition
The trial edition cannot execute the operation
Please enter the serial number you received to activate the product:
Serial Number :    [_______________________________________]
X Please enter the valid serial number in the input field.
If you don`t have the serial number, please purchase it. Buy Now
shutter
Fixes: 65
Further investigation reveals....
I tried to "erase" the contents of the Linux hdd,.. through "Eraser 5.6" via the Windows hdd (as it now showss the drive ( F: ) and the contents on the "computer" .. however.. the erasing reports "failed" against all the files and also...........
"The media is write protected"...
don`t know how that works ( or not ) as I never made the hdd write protected..... ( wouldn`t know how to....  ! )
EDIT EDIT EDIT EDIT
Just put a Mint17 hdd in the laptop... and the "offending" linux hdd in the caddy... ( shows on the "computer" )  however cannot "open" it to reveal the contents... as Mint 17 says it is unable to mount the drive.... right clicking on it again... then "properties"... then "permissions".///  i t states
"The permissions of Hitachi xxxxxxxx could not be determined"...
VileReynard
Fixes: 20
Try using Linux with gparted.
Is the disk formatted in the GPT or MBR style?
shutter
Fixes: 65
Did you see the Edit  above ?  before posting... ?
Don`t know/understand "gparted"... so would need some guidance on that, please....
Don`t know whether it is GPT or MBR either ! ! .....
shutter
Fixes: 65
Hmm..... On the Mint 17
Menu  >  Preferences > Disks  ( Manage Disks  & Media ) >
Offending drive ( Hitachi ) shows as 250 gb with fee space of 250 gb ...  clicked on the + sign... and it gives the option to erase the contents.. and also to change it to NTFS .. so clicked on Erase ( don`t overwrite) (quicker)... and within seconds, it shows the rive as
Filesystem
Partition 1
250GB NTFS
Now rebooted with my windows hdd in the laptop.... the offending Hitachi hdd now shows "this folder is empty".. with 232GB space...
control panel > Admisinstrative tools > Computer Management > Storage > Disk Management shows
(F:)
232.89 GB NTFS
Healthy (Primary Partition).
So ,... hopefully,.. all is now done ! ! ! ...
PeeGee
Quote from: shutter
Aaah, Mint disk management as suggested in #12  Cheesy
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
shutter
Fixes: 65
Ha Ha !... you could have saved me a lot of time and frustration if you had said....
something a little more clear.... like....
on a Linux Menu ...
And I would have known what you meant ! ! !  Roll_eyes Roll_eyes
twocvbloke
Quote from: shutter
Weird, I've been using EaseUS for a few years and it's always been free to use, I shall check that link, see what's what...
Did you download the Free version or one of the paid versions? If the latter I think they do indeed put those into trial mode so you can't actually use them, which is kind of annoying to say the least... Roll_eyes
Bit barn door I know, but it's got me wondering now... Huh
shutter
Fixes: 65
yeah downloaded the free version.... never mind.... !  I have now managed to get that hdd formatted properly... and..... got windows vista to load up on it.... and now in the process of downloading and installing ALL my favourite progs...so I have a nice new clean copy of windows and it should run better...
Many thanks to all for their contributions... have learnt a lot over the past few hours ...  Wink
PeeGee
Quote from: shutter
I would have said "Menu > settings > disks" for Mint/xfce or "Menu > System > YAST > Partitioner" for openSUSE/KDE, as that's what I use Cheesy
Phil
shutter
Fixes: 65
Butcher dint  !!!  Grin Grin Grin
