Unable to download Avast updates
FIXED- Subscribe to RSS Feed
- Unable to download Avast updates
08-04-2018 6:11 PM
As the title says I'm unable to download the latest Avast update. If I try it through the software it says 'Invalid File Signature' and if I try through the Avast website the download says 'Failed - Network error'.
I've also noticed that some of my podcasts are refusing to download from my laptop, although I can through my iPad.
A while ago I had a similar issue that was solved by putting the DNS settings to 8.8.8.8 and 8.8.4.4 for the TCP/IPv4, is there something else that I need to fix?
Thanks,
Ben
Fixed! Go to the fix.
Re: Unable to download Avast updates
08-04-2018 6:31 PM
Moderator's note by Mike (Mav): This thread is now in the appropriate board.
Forum Moderator and Customer
09-04-2018 7:55 AM
Thanks for the reply. Unfortunately I'm unable to even download the latest version of the Avast installer from their website as it has the 'Network error' issue I detailed in my first email.
09-04-2018 8:17 AM
Some malware will change your DNS server to one of its own and use this to prevent you from accessing web sites that you might visit in an attempt to remove the malware.
09-04-2018 12:40 PM
Sounds like you have a virus/malware on your system, presuming they are microsoft, iPad (apple) not as prone. If you are able to get into avast do a boot time scan to see if that resolves your problem.
09-04-2018 1:22 PM
My first action would be to try to download Malwarebytes and run that to see if there are any nasties lurking on your computer.
16-04-2018 7:49 PM
I finally managed to do a boot time scan and that seems to have fixed both issues. Thanks.
