The usual GNOME annoyances
ejs
Fixes: 25
I'm finding the new behaviour of the scrollbars in GNOME 3.6 (well, in GTK+ 3.6 to be exact) incredibly annoying - when you click above or below the slider on a scrollbar, instead of scrolling up or down by a "page", like they have done for many years, instead you now jump to wherever you click.
I pretty much always want to scroll up or down by one page at a time, and can't think of much use for instantly jumping to the middle, especially in a terminal with infinite scrollback.
Perhaps they'll reverse up and down next, otherwise it might be confusing that when you scroll down, what's on the screen moves upwards!
26 REPLIES 26
HairyMcbiker
Fixes: 21
Re: The usual GNOME annoyances
Quote from: ejs
That has already been done, its called "natural scrolling"  Crazy
Natural to who? Totally alien to me - a home computer user for 30+ years
Had to disable it on Mint cinnamon edition was driving me nuts.
ejs
Fixes: 25
Shockingly I have discovered that there is a setting to put the scrollbars back to the way they were:
~/.config/gtk-3.0/settings.ini
[Settings]
gtk-primary-button-warps-slider = 0
However, removing the tree sidebar from "Files" (nautilus) seems a bit harsh. And harder to undo that decision.
VileReynard
Fixes: 20
I always get rid of that annoying side-pain in Nautilus...
However, I find two short-cuts CTRL+H and F3 (separately!) to be really useful.
ejs
Fixes: 25
nautilus, or rather "Files" as it is now known, has been quite thoroughly ruined for GNOME 3.6. You can't even type the first few characters of a filename to jump to it in the list - instead, doing that switches it to search mode, and it gives you a list of search results. The status bar is gone, instead you get a tooltip at the bottom if you select something, which will jump from side to side if necessary to dodge the mouse cursor.
Control+H - show hidden files, I always have them shown. Can't remember what F3 does, if it was for the extra pane, that's been removed.
VileReynard
Fixes: 20
Yes - it's the split pain view.
I believe Mint(?) has plans to fork Nautilus - called Nemo  Grin Grin Grin
See http://www.webupd8.org/2012/08/nemo-linux-mint-team-forks-nautilus.html
Waldo
waldo@gouda:~$ apt-cache policy nemo
nemo:
  Installed: 1.0.9-0ubuntu1~precise1
  Candidate: 1.0.9-0ubuntu1~precise1
  Version table:
*** 1.0.9-0ubuntu1~precise1 0
        500 http://ppa.launchpad.net/gwendal-lebihan-dev/cinnamon-stable/ubuntu/ precise/main amd64 Packages
        100 /var/lib/dpkg/status
Nemo has been in Cinnamon for a little while now.
ejs
Fixes: 25
The MATE desktop, cinnamon, nemo are all in Fedora.
VileReynard
Fixes: 20
Cinnamon is definitely a Mint thing.
Apparently Nemo also originated with Mint too - but Nemo isn't ready for anything but testing.
ejs
Fixes: 25
That doesn't mean they're exclusive to the Mint distribution.
HairyMcbiker
Fixes: 21
No just that they started with Mint. The Mint Menu and Mate/Cinnamon are in use by a couple of other distro's as well.
Waldo
Quote from: Un
[...]but Nemo isn't ready for anything but testing.
I think it's being tested for inclusion as the default file manager in Mint 14 / Cinnamon (expected by the end of the month).
VileReynard
Fixes: 20
I find Mint's "upgrade" mechanism (or lack of it)  hard to use.
So I'll stick with version 13 = Ubuntu 12.04 LTS version for the next 18 months.
HairyMcbiker
Fixes: 21
Yes that is a bug bear with Mint, the upgrade path is to reformat and re-install (keeping the /home if it is on a separate partition)
Re-installing all my "normal" apps can be a pita, but it does result in a clean system.
I make backups of /etc and a few other scripts I have installed to do stuff like cron etc.
Still this time I can remove the 3 other OS's I haven't used in the last 5 months since moving to Mint 13 Mate. But I will probably install a test machine in/over one of them to trial it before I jump.
I have LMDE installed on a laptop and the upgrade mechanism on it is via "apt dist upgrade" using a service pack type upgrade to move to the new version. But it does involve downloading lots of data. (and needs a lot of space free in /tmp)
ejs
Fixes: 25
I've recompiled nautilus with a tiny patch to restore the normal "typeahead find" behaviour:
--- nautilus-3.6.2/src/nautilus-list-view.c.orig	2012-10-29 22:40:48.000000000 +0000
+++ nautilus-3.6.2/src/nautilus-list-view.c 2012-11-06 12:34:36.205716427 +0000
@@ -1375,7 +1375,7 @@ create_and_set_up_tree_view (NautilusLis
g_str_equal,
(GDestroyNotify)g_free,
(GDestroyNotify) g_object_unref);
- gtk_tree_view_set_enable_search (view->details->tree_view, FALSE);
+ gtk_tree_view_set_enable_search (view->details->tree_view, TRUE);
view->details->drag_dest =
nautilus_tree_view_drag_dest_new (view->details->tree_view);
