Raspberry Pi WirelessLessNess
- Re: Raspberry Pi WirelessLessNess
15-12-2016 9:06 PM - edited 15-12-2016 9:08 PM
I want to solve a problem with my Raspberry Pis losing wireless connectivity. They've always done it but it's bugging me now as every so often the clients for my music server, and the one that supplies my amateur radio hotspot drop out.
I have all of the Pis set to do a reboot on cron during the night to stop them hanging occasionally. This works fine but doesn't prevent the wireless from dropping out. Rebooting the router fixes it for a few days but after that it happens again. Rebooting the Pi doesn't reconnect to the router after it's dropped the wifi. So it seems more as though the router is somehow refusing the Pi's request for a connection. Fixed IPs or not makes no difference, time to fail is around 3 days.typically.
I'm still using the PN-supplied TG582n as it has generally been fine for me although it doesn't get much of a write-up. Anyone know what the problem might me and whether shelling out on a more capable router might fix it? I don't fancy just trying one on the off-chance (Scots y'know )
16-12-2016 4:02 AM
16-12-2016 9:21 AM
What build are you using on the Pi's? I used to use a Pi for OpenVPN (tried wired and wireless) and using the Noobs build I found the same would happen to me. The network would respond sometime, but other times I could not connect to the VPN despite everything being connected and powered up, eventually it would reconnect but it seemed like the Pi's network would just go to sleep using the Noobs image and I couldn't stop it. I eventually moved onto different hardware for the vpn service. My Pi is currently gathering dust.
![](/skins/images/227CE3BD5A7F5638EDF9976F1BCF977A/responsive_peak/images/icon_anonymous_message.png)
16-12-2016 9:26 AM
@quelquod, Instead of using cron to reboot why don’t you change the job to ping the router (gateway) every X hours, to put some traffic through the interface, or change the WiFi power management so it doesn’t go to sleep.
16-12-2016 10:31 AM - edited 16-12-2016 10:32 AM
Yep - tried everything like that. It's a puzzle. Tried leaving the music client running continuously but the wifi connection still goes down (although if I connect via Ethernet I can see that the client is still running). If I connect to the pi (wired) the wireless is disconnected and reconnecting doesn't work. If I check the router the Pi reports as disconnected. If I reboot the Pi nada. If I reboot the router it all wakes up. I get the same on the latest Jessie build. I feel that the problem is at the router end, but why only on the Pis?
16-12-2016 10:50 AM
@quelquod - Would the fact that you’re connecting via the physical NIC have anything to do with it? Because as soon as you connect using it you’ll lose the WiFi which may not, if at all, recover until the physical connection is removed.
Is there anything on your network that uses the LAN based IPs of these devices that could be causing the above?
Also are you running propriety firmware drivers for your WiFi dongle? If not then it might be worth seeing if these are available.
16-12-2016 11:47 AM
How about using a crontab to do a small wget from an external web site (such as bbc.co.uk) and write the date, time, etc to a logfile on the Raspberry at minute intervals to see if a pattern emerges?
16-12-2016 2:17 PM
I'm not so sure that connecting via Ethernet would/should disconnect the wifi - there's no (well, shouldn't be any) reason why the processor can't maintain more than 1 network connection on different addresses and I notice that I can ping both addresses concurrently.
My radio hotspot is at the end of the garden and I've never hooked it up via Ethernet anyway, but it still disconnects regularly. It's odd that rebooting the router with no action at the processor end fixes things.
I cant think of any reason there should be an IP clash, no fixed IPs (apart from the router/modem) and the router handles the dhcp.
16-12-2016 2:19 PM - edited 16-12-2016 2:21 PM
Yes, that'd probably be worthwhile, I'll just set it to ping the router and log it to see if anything springs to mind.
Actually, as a sledgehammer approach I've currently set one of the Pis to reboot the router and then itself at 3am. Oddly (?) that seems to work OK but I'd rather solve the puzzle than just hide it.
