Help Needed Please with my Printer
- Re: Help Needed Please with my Printer
30-04-2015 2:49 PM
22-06-2015 1:29 PM
Now that you are on Fibre, if you need to reboot the Router, that won't have an adverse effect on the modem. You can certainly log into the 582n and look at your Home Network Wireless Netrwork and Devices to see if it registered.
22-06-2015 11:34 PM
If i click on IP Manual i have to click on the add option then it comes up with Printers IP address which i don't know so i cant go any further. As i say im not technically minded.
23-06-2015 8:17 AM
23-06-2015 8:44 AM
23-06-2015 10:30 AM
Could upgrading the firmware have turned the wireless OFF by default? I wouldn't have expected it to but maybe...
Quote This is rather odd, why the Wireless on the TG582n should be any different in Fibre mode from ADSL mode I'm not sure.
@bustermissy1961, Is the WifI light illuminated on the router ? if not the press it briefly(it's also a button) and the light should illuminate and turn the Wifi on.
23-06-2015 10:35 AM
Quote from: dvorak assume you've pressed the wps button on the printer again to reinitialize the setup?
Yes i have but no joy.
23-06-2015 10:37 AM
Quote from: MisterW Could upgrading the firmware have turned the wireless OFF by default? I wouldn't have expected it to but maybe...
Yes its lit up green.
23-06-2015 11:57 AM
I'm with AO then, I can't see that anything should change on the Wifi when going from ADSL to Fibre. I guess the SSID MIGHT just be different on the new version of firmware but I wouldn't expect it to be, and the printer should still see it anyway...
23-06-2015 11:47 PM
24-06-2015 9:23 AM
Quote When i click the Search for wireless devices its not picking my WIFI printer up
leads me to think that as you are having the issue with two routers it must have something to do with the printer. Have you tried a factory reset of the Printer?
In the meanwhile, we'll try and resolve your other specific 582n "issue" on the other thread.
24-06-2015 9:31 AM
have you tried switching off all the Wi-Fi devices and also turning off all the wired devices then restart the router and then turn on the printer and see if tapping the wps buttons on both router and printer enable them to link up ?
it could be there is a problem with the printer's network settings but deleting the old network and then pulling the power cord out of the wall for a few minutes should make it able to make a new connection.
and if you need help on sorting out the problems then this https://www.epson.co.uk/gb/en/viewcon/corporatesite/products/mainunits/support/12298 may be of use to you
24-06-2015 10:10 AM
29-06-2015 12:46 PM
30-06-2015 10:40 AM
