HG612 & OPNSense Firewall
OsoPolar
Re: HG612 & OPNSense Firewall
These are my options
https://i.imgur.com/5qtJ5oC.png
On my Zimma box i have 2 ports
1. For modem
2 From Zimma into Switch
Fixes: 396
Then either leave it as gateway or select router it shouldn't matter as you're not using its wan port
Connect the switch to the zimma. Connect a lan port of the r7800 to the switch . Make sure that dhcp is disabled on the r7800 ( your previous post showed it enabled )
OsoPolar
HI
If i check the photos it clearly shows disabled !!
https://i.imgur.com/hXvl3G7.png
Fixes: 396
In that case it should be fine
RealAleMadrid
Aspiring Hero
Fixes: 59
@OsoPolar  Are you sure? The image shows DHCP server enabled.🤔
OsoPolar
HI
Sorry you have me confused he mentioned it should be disabled but i had it enabled ????
RealAleMadrid
Aspiring Hero
Fixes: 59
@OsoPolar  Where is there any confusion, for use as an Wireless Access point as @MisterW has already stated the R7800 should have DHCP disabled. Your previous posts have shown it as enabled which is incorrect.
