Email setup
petlew
Email setup
I have passed on to a friend my "old" Samsung Galaxy Tab 10.1. In fact it is hardly used. But has been returned to factory setting before handing over.
The problem he is having is with email set up; having apparently successfully completed the set up mostly automatically. Sending is normal. But receiving is not. I can send him an email which reports to me "message sent" no report of being undeliverable, but the mail doesn't appear in the Galaxy Inbox.
I'm guessing this is an error somewhere in the account settings, but it all "looks" ok. What the receiving set up lacks is a port number, I wonder if this could be the problem?
My friends ISP is Sky.
4 REPLIES 4
ReedRichards
Seasoned Pro
Fixes: 25
Re: Email setup
Sky seem to use Yahoo for their email.  There are instructions here https://www.sky.com/help/articles/getting-started-with-sky-yahoo-mail.  The Android instruction mention the need to generate an app password on older Android versions.  Incoming mail settings are below.  The port numbers are standard so unlikely to be wrong.
Username: Your full Sky Yahoo Mail address
Password: Your unique 16-digit app password
Incoming server information:
Host Name/Server:
POP: pop.tools.sky.com
IMAP: imap.tools.sky.com
Security type: SSL
Port:
POP: 995
IMAP: 993
petlew
Re: Email setup
As ever ReedRichard, many thanks. My friend is away for a couple of weeks now, but I'll pass this on when I see him next.
petlew
Re: Email setup
Ooop's, I gave myself credit for the fix.
Can a mod fix it please?
Mav
Fixes: 516
Re: Email setup
Moderator's note:
@petlew
Fix fixedWink
Forum Moderator and Customer
