WPS light flashing on 2704n router
- My Router
- WPS light flashing on 2704n router
05-03-2020 10:18 PM
The WPS light is flashing on my 2704n router, although the internet is working fine.
Would a factory reset (using the pin-hole) remove this without stopping the internet from working as before?
Message 1 of 3
(2,135 Views)
2 REPLIES 2
Re: WPS light flashing on 2704n router
05-03-2020 10:26 PM
One of the two buttons on the edge of the router should turn the WPS off. The other button will turn off WiFi altogether, I can’t remember which way around it is. Good luck.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Message 2 of 3
(2,132 Views)
06-03-2020 7:02 AM
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Message 3 of 3
(2,082 Views)
- My Router
