Specify devices on 2.4Ghz and 5Ghz
- My Router
- Specify devices on 2.4Ghz and 5Ghz
29-01-2020 7:53 PM
Hello,
I am wondering if it is possible to specify what devices connect to 2.4Ghz and 5Ghz with a bound WiFi network.
I want everything under the same SSID but want to specify what is on each band.
Ideally I would like everything in the room with my router on 5Ghz then everything else in the house on 2.4Ghz. I cannot see a way to do this without splitting and renaming the networks.
It seems possible to do this on the latest BT home hub. Plusnet use the same hubs I believe.
Cheers,
Chris
Cheers,
Chris
Labels:
Message 1 of 3
(1,799 Views)
2 REPLIES 2
Re: Specify devices on 2.4Ghz and 5Ghz
29-01-2020 10:01 PM
29-01-2020 11:56 PM
Thanks, I have since done that and it has improved things. I was concerned devices (amazon echo, phone etc) wouldn’t talk to each other across the two networks but it seems to be ok.
Message 3 of 3
(1,753 Views)
- My Router
