Should I Swap Asus n56u with BT Hub 6?
- My Router
- Re: Should I Swap Asus n56u with BT Hub 6?
06-08-2018 3:37 PM - edited 06-08-2018 3:39 PM
I have 8 devices running on my Asus N56u, Even though new devices are 5ghz I get complaints saying its slow and have to revert back to 2.4ghz.
PS4 online and Youtube is constantly used all day long, I get the odd moan here and there of lag, which might be PS4 servers or ISP related.
I am on fibre and get constant 38+mb speed wired/wireless.
So I was looking at the BT Hub 6 which has 7 Antennas ( 2 more then the Asus N56u) and was wondering is it worth me buying a cheap HUb 6 from ebay as the N56u is very old.
I get -44 RSSI on wifi Analyzer and thinking if i have 7 Antennas may it'll be more lower.
Thanks in advance for your help.
06-08-2018 9:31 PM
I doubt you’ll get a clear answer on this. I would get a Smarthub 6 and try it. You can always sell it on or keep it as a spare router. Alternatively you could use the Smarthub as your router and maybe use the Asus in Access Point mode to improve wireless coverage
07-08-2018 8:52 AM
Hello,
Please take a look at https://www.howtogeek.com/222249/whats-the-difference-between-2.4-ghz-and-5-ghz-wi-fi-and-which-shou...
It may explain your situation.
Dan
07-08-2018 9:02 PM
I was hoping somehow to catch anyone who has jumped from a similiar router to bt hub 6, They advertise it as best coverage, Like you said no harm in trying and sell it on or i never thought about your 2nd suggestion. thanks
07-08-2018 9:03 PM
Only the Ipad 4 runs smoothly on 5ghz, the Iphones are ridiculously slow and disconnect.
08-08-2018 4:58 PM
The Hub6 does get some good reviews about having great coverage but I'd have expected the Asus to at least keep up to a certain degree even though it isn't AC.
10-08-2018 8:05 AM
I had the TP Link W9980 for a couple of years followed briefly by the Plusnet Hub One before switching to The BT Business Hub 6 which I got for a good price from Ebay.
Really very pleased with the wireless performance, it is rock solid. My main computer is connected by Ethernet, but a quick scan has just shown about 16 devices connected wirelessly to the Router ( family visiting for a couple of weeks ) I'm seeing 3 iPads, 2 iPhones, 4 Android phones, 1 Chromecast, 2 Alexa devices and 2 Google Home devices and a Printer. ( not all connected at the same time, but registered with the WiFi )
All are connecting without issue and Netflix streaming is not affected.
So I'd say go for the BT Hub 6, the Business version has more control available than the domestic version and they are both available for a good price if you check out Ebay / Gumtree
13-08-2018 2:20 AM
Im on 41mb speed, are you on similar speeds?
Just trying to see if speed might be effecting my issue or router.
We never watch tv and constantly streaming and gaming online.
13-08-2018 7:05 AM
13-08-2018 12:43 PM
Hey @Faizan786
While I can't provide assistance on choosing a third party router (As I personally find the Hub One does the job for me), I've checked things out this side and all seems OK including the VLAN which is showing as green on the latest report.
Do you know if the issues occur solely over WiFi or via ethernet too?
- My Router
