Plusnet new hub
geekinator123
Plusnet new hub
It's been nearly 5 years since the release of the Hub one. Does Plusnet have any plans releasing a better router anytime soon?
3 REPLIES 3
Fixes: 1,485
Re: Plusnet new hub
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 420
Re: Plusnet new hub
@geekinator123
If they are then they are not sharing the information. Much effort at the moment is being spent trying to fix the flaky Hub One firmware.
If you want something better then spend very little money on a BT Smarthub 6 from the likes of EBay. You will find a post giving you the setting instructions pinned near the top of this Router board.
MatthewWheeler
Fixes: 480
Re: Plusnet new hub
Thanks for your post @geekinator123
We have no plans at this moment in time I'm afraid
 Matthew Wheeler
