New Asus DSL-AC88U works Great with Plusnet
- My Router
- Re: New Asus DSL-AC88U works Great with Plusnet
14-03-2017 9:42 PM
Went in to PC World this afternoon, and they had the Asus DSL-AC88U in stock on shelf priced at £209
bought a unit and it works great.... with plusnet put the settings in manually... working fine current down stream
SNR 6.2 dB so far so good.
14-03-2017 10:03 PM
yes its a great router i got one last year
14-03-2017 10:10 PM
It only was released for sale March 2017 it is the DSL version not the RT version...
you sure you bought the DSL version successor for the DSL-AC68U
15-03-2017 4:35 PM
All the smiles have gone now, up and running, surfing and good wireless connectivity, sadly I cant get the router to work
with LAN IPTV to watch paid services ie BT Sport via PlusNet Youview box .... with its settings very limited compared to the dsl-ac68u, which I have resorted back to until a new firmware, be nice to know if someone can get it working with the original firmware and post some settings.
22-03-2017 11:48 AM
Still No firmware update to view PlusNet Youview Paid Services... resorting to using AsusDSL-AC68U
Re: New Asus DSL-AC88U works Great with Plusnet IPTV Services !!
31-03-2017 5:50 PM - edited 31-03-2017 5:52 PM
Update SUCCESS on getting to work BT SPORT + HD IPTV Paid PlusNet channels to work at last...
this router is now much better than the previous mediate chipset router dsl-ac68u... sync's better and
has some how a better speed imho the new router uses a Broadcom chipset.
31-03-2017 9:06 PM
Congratulations on getting the IPTV working.
Would you care to share the settings for future reference should anyone else want to use this device and have working IPTV? It seems to be a black art to get IPTV to work.
31-03-2017 10:24 PM - edited 31-03-2017 10:47 PM
Used Quick Internet Setup, UK ISP PlusNet VDSL + Youview TV username and password. Set up Wifi
These are my settings from screen shots hope this helps, was sent zip file from Asus to load onto my firmware
which works, should then be uploaded into the next update upgrade firmware as one from Asus website.
My Youview box is connected by Ethernet cable to Lan Port 1 for this to work correctly as in the screen setting for Wan Bridge Internet Connection if you use another LAN Port it will NOT Work... hope this helps you understand the setup.
01-04-2017 11:52 PM
hi is it possible to get the file from you on this forum please. thanks
02-04-2017 9:07 AM
350 would have to email it
02-04-2017 7:05 PM
@turb-z email sent to you hope it works.
18-04-2017 9:52 PM - edited 18-04-2017 10:41 PM
@mharvo Have you seen that .351 is available?
Forget that, seen some of your posts there!
20-04-2017 5:14 PM - edited 20-04-2017 5:15 PM
Yes if anyone has this router you NEED Build 351 to get perfect service with PlusNet and PlusNet IPTV PAID Services
these screen shots will BE NO LONGER WORKABLE due to NEW/Latest Firmware.
25-04-2017 8:30 PM
Just got the DSL-AC88U and updated the firmware to Build 351, wouldn't detect my Plusnet VDSL line, and on inputting the details manually it connects but reports as being Annex B, also doesn't see all my devices in network map and those it does it won't let me change the name or icons of the devices.
I'm coming from a DSL-AC68U on the latest firmware and it seems more usable at present, anybody still on Build 350 with the DSL -AC88U that can confirm they are having the same issues as me before I try flashing the older firmware..?
Cheers
MarkC
25-04-2017 8:50 PM
Have a look here, it would appear that Annex B is correct.
I also can't change device name in build 351.
- My Router
