Hub Two
janliz
Hub Two
Trying to set up new Hub Two router but the 3 pin part of the old hub power supply doesn't click in to the new part. The connectors are in different places. Any ideas?
5 REPLIES 5
Legend
Fixes: 254
Re: Hub Two
Use the full plug and power supply supplied with the new Hub?
Fixes: 417
Re: Hub Two
@janliz  Welcome to the forum.
The Hub Two should have come with its own 2 part power supply.
Fixes: 1,483
Re: Hub Two
Moderators Note
This topic has been moved from Fibre to My Router
mechanic123
Re: Hub Two
But what we really want to know is; is this new hub any better than the previous default offering from PN? Did they sort out the performance issues with the original?
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: Hub Two
@mechanic123  It's a rebadged BT SmartHub2 which is a much more recent device than the Hub1 (BT HH5). The general consensus is that it is a lot better, particularly the WI-FI  which has no performance issues, although it does have the annoyance that the 2.5 and 5Ghz bands cannot be split with different SSIDs. This can be useful with fussy Apple devices.
