Hub One LAN setup issues - switching from Sky ER115
Aspiring Hero
Fixes: 80
Re: Hub One LAN setup issues - switching from Sky ER115
requires elevation?
You need to run the command prompt as administrator, click on start, type cmd and you should see the option required.
I see there are a couple of troubleshooting tips in the user guide, I would have expected the 4 second reset to work.
Dan.
