Hub One - 5GHz WiFi issue
skicat
Re: Hub One - 5GHz WiFi issue
HI @bobpullen , I know you've been away for a week but would it be possible for you to push the .273 firmware update to my router please? You already did this several months ago which fixed my wi-fi issues, but the router has just been replaced for a different reason. The new router has come with the .263 firmware so I'm back to square one with the wi-fi.
Many thanks,
KingRonseal
Wayblack,
I used the instructions here https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673 .
Very straightforward, only point that I got stuck on was number 8, and that was because I didn't read the second part of it properly.
Doesn't take long either.
wayblack
Thanks KingRonseal...., like my last post this should help others who need this information, cheers.... 👍
JestersTear
Still dropout free on the BT HH6 after 3.5 weeks and I'm working from home RDP'ing to servers and user PC all day - before was a nightmare withe the PN Hub One. Better range on 5ghz too with HH6.
Anyone having issues, I would urge you to grab a cheap one.....it will save you hassle in the long run and dead easy to setup
Once my contract with PN is up its BT FTTP all the way.
frankc52
At the end of the day, it's better the devil you know IMHO and if all is working ok why leave? If you goto BT you get the same network and most of the managers are employed under a BT contract but you are getting a cheaper deal with PN and the mobile deal is quite good again using EE via Plusnet mobile which BT owns. £6 for unlimited calls with 4Gb data. The only downside they don't offer 5g at the moment.
Tags (2)
stumpypete
@bobpullen
I am experiencing the 5GHZ issue now. First time it has happened today.
Plusnet Hub One | Software version 4.7.5.1.83.8.263
Serial No +081441+NQ01007067
Longliner
Seasoned Pro
Fixes: 7
Agreed. PN uses the BT network, I quit BT for PN and find no difference in service but a MUCH lower monthly bill 😊
bobpullen
Fixes: 316
@skicat @sgoodrick @TJohnDoe @Wizzkidy @steve81 @bricktrix @Jesspj91 @Droppedtuba @Paulgriff100 & @stumpypete - I've pushed the change to your devices. You'll need to reboot at you side to apply the update.
Hope it helps!
bobpullen
Fixes: 316
@HushTheVoices & @lloyd_634 - I tried the same with your routers but from what I could determine, they weren't online?
@Moyano & @kostas - I've struggled to locate your accounts, so you'll need to drop me a private message containing your router serial numbers and account usernames.
@Tonymcclennon2 wrote:
Unfortunately, despite an update to v273, the connectivity is so slow that I ended up buying a BT Home Hub 6 from Facebook Marketplace for £10. This has certainly speeded up the connections from devices - as an example, my Lenovo Laptop was showing download/upload speeds of 26.1/16.8Mb through the Plusnet hub, but 68.8/16.1Mb through the BT hub.
Slow throughout on the 5GHz channel is a slightly different issue. It is being discussed over here. To summarise - we have fixed the issue and it will be rolled out as part of a future update.
Droppedtuba
Great thanks Bob, really appreciate all your efforts here.
I have tried turning the 5ghz channel off for the last couple of days and it does seem to be better with no noticeable drop outs since. I’ll see how the update goes.
Thanks again
Paulgriff100
Many thanks for the pushing me the update Bob, I’ve re-enabled 5ghz and just put my iPhone on it for now leaving everything else on 2.4ghz while I ensure all is well.
skicat
Thanks @bobpullen , I've applied the update. Hopefully all working now 👍
lloyd_634
Hey @bobpullen
I'd switched to my old BT HH6 temporarily. I'll get my Hub One plugged back in and online now ready for the next time you can roll the update out.
Thanks!
DeeAJay
Thank you @bobpullen  Devices are connecting to 5GHZ now and everything is working faster than it was.
PT1
Hi Bob,
I am experiencing unstable WiFi connections with my 5GHz connection as well. The router is running with software version 4.7.5.1.83.8.263 and the 2.4GHz, 5GHz channels are merged.
Many thanks,
PT1
