Bridge Mode: Smart Hub 2 + TP-Link DECO M4
Obelix27
I am trying to use a DECO M4 mesh with a Smart Hub 2. Surprisingly it works with both the DECO and SH2 in router mode, but I want to do the correct thing and set the SH2 to "Bridging Mode" to avoid conflicts. When I set the SH2 to Bridging Mode I get a purple light and nothing works. I couldn’t even access the Smart Hub's settings via 192.168.1.254 (I also tried 192.168.1.1), and had to factory reset the SH2. I tried connecting the PC to the LAN1 and WAN ports.
How do I get the SH2 to work properly in bridging mode so that it works properly with the Deco M4 in router mode?
8 REPLIES 8
Fixes: 420
Re: Bridge Mode: Smart Hub 2 + TP-Link DECO M4
@Obelix27  Welcome to the forum.
Have you set the Deco to router mode, PPPoE and entered your Plusnet username and password?
Obelix27
I haven't no, and will do when I get that far. But the Smart hub 2 got the purple light (what does that mean?) and I was unable to configure the SH2 at all (e.g. take it out of Bridge mode). Surely I should be able to do that without any router attached? Also which LAN port do I connect to when in bridge mode?
Fixes: 420
@Obelix27
It means that it is working but not connected to the Internet, which it won’t unless you set the Deco up correctly. To revert the Hub 2 simply push a paperclip or similar in the reset hole on the back. Hold the switch closed until you get a green light.
Use any of the LAN sockets to connect to the Decp
Aspiring Hero
Fixes: 84
@Obelix27
for clarity are your referring to the PlusNet Hub Two or BT Smart Hub 2?
On a Hub Two in bridge mode the led is pink when in bridge mode and on mine looks more purple!
Obelix27
Perfect, that now makes sense. Thank you! Final questions:
I am on a plusnet smart hub 2, the light definitely looks purple to me!
- So when I put it in Bridge mode it loses all the router settings, Admin login etc. as I have to factory reset it.
- Am I right in saying that both the DECO and SH2 shouldn't be in router mode? What actually is the problem as it seems to work quite well!
- finally what is the difference between the WAN port and LAN1-3?
Fixes: 420
@Obelix27
When in bridge mode the hub turns into a dumb modem, which converts the multi frequency broadband signal from the BT FTTC cabinet into a digital stream. All settings have to be entered into a separate router. If both units are in router mode you will double NAT. See here for more on this. https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
Aspiring Hero
Fixes: 84
In answer to:
When you are in bridge mode the HUB is only a modem and the router is turned off, so those functions will not longer be available to you. On my Hub Two I see limited information on the Home >Status and Advanced Settings >Technical Log >Information, for this to work you need the PC to have a IP address network address in the 192.168.1.0/24 range
You need to setup the DECO as a router and look for PPoE connection in the WAN setup, in there you add your plusnet username and password
Router to Router introduces Double NAT, see https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
You should connect the Deco to LAN 1 to 3 NOT the WAN port. WAN port is to connect the device to a ONT for full fibre
HTH
Dan
Obelix27
thank you - everything much clearer now! Let me test it this w/e and I'll mark a reply as Problem Fixed
