Full fibre upgrade gone wrong
FIXED- Subscribe to RSS Feed
- My Order
- Re: Full fibre upgrade gone wrong
02-12-2023 10:57 AM
@Star-Light100 - Deary me, I'm sorry for all of this. I've got you booked in for Monday AM than with Openreach and I'll be in touch on Wednesday when I'm next in. Feel free to give me a shout if you need anything in the meantime.
02-12-2023 11:04 AM
02-12-2023 11:13 AM
02-12-2023 12:39 PM
@Star-Light100 wrote:
Hi. I’ve reset the Hub again and re added my account details again and no change. It says connecting and then comes back with disconnected in the hub. Still stuck on the orange solid light on the hub. Thanks
After a factory reset a Plusnet hub is designed to contact the Plusnet management platform and change the username and password automatically to your account details.. If you are having to do this manually then there is a break in the link.
04-12-2023 6:23 PM
04-12-2023 7:25 PM
Hey there @Star-Light100 I can see you have spoken with an agent on our side and they are pushing this back to CAT to deal with it from there. I am sorry about this.
05-12-2023 5:43 PM
05-12-2023 6:30 PM
I'm really sorry this still isn't fixed, especially after an engineer has been out to take a look at it.
I need to respond with a bit of account sensitive information so I've popped an update on your account here: https://www.plus.net/wizard/?p=view_question&id=238056268
05-12-2023 7:55 PM
I will wait and see what PlusNet come up with next to fix the issue. But this needs to be fixed as it’s been dragging on far too long now. I was once a happy PlusNet customer before fibre came along! And I would like to once again to be a happy PlusNet customer. Thank you
06-12-2023 8:03 AM
The engineer that came was no help and didn’t want to test anything. He just made a phone call and blamed PlusNet. I was hoping he would test the wires. But he didn’t.
If the ONT is showing green lights then there's nothing that the engineer can check, except the ONT serial no and from what I can see , that's already been checked. The current system whereby all an ISP can do is request an OR engineer seems flawed for these type of faults. It needs the ISP's support to be able to have the ability to communicate with OR 2nd line support to check the circuit build and routing, which can be done without an engineer attending..
06-12-2023 11:34 AM
I can see our CAT team are arranging for a new router to be sent to rule this out as the cause of the issue.
We'll get that out to you as soon as possible
06-12-2023 11:49 AM - edited 06-12-2023 11:50 AM
@MatthewWheeler That isn't very encouraging, sounds like clutching at straws. Seems like there are no decent diagnostics to find out why FTTP connections are not working.
@Star-Light100 To test if the HUB is the problem you can set up a PPPoE connection on a PC with your Plusnet credentials and connect it directly to the ONT, so not using the HUB. If you're not sure how to do this google will help.
06-12-2023 12:04 PM
@MatthewWheeler I'm with @RealAleMadrid here, I'd be amazed if it was the router!
Has anyone checked to see if PPPoE authorisation attempts are hitting the PN gateways ? If they're not , then surely the problem is in the OR/BTw systems ?
06-12-2023 12:52 PM
06-12-2023 2:45 PM
Work has been done now and it should be up and running soon
@MatthewWheeler from that, can we take it the problem has been identified and fixed ?
- My Order
