Fibre order
- My Order
- Re: Fibre order
Fibre order
07-08-2018 8:36 AM
What is happening with my order?
No answers to my questions on ticket number 179021266.
I've not received a router either and from what I can gather on the website it doesn't look like it's been ordered yet.
Regards
Ian
Re: Fibre order
07-08-2018 5:11 PM
Hi Ian.
Apologies if you've not received an update from us. I've sent an update to the ticket which you can view by logging on via https://www.plus.net/wizard/?p=view_question&id=179021266 .
Thanks - Tahir
Re: Fibre order
08-08-2018 8:20 AM
From the ticket, this worries me:
"The engineers will need to work at the local exchange to remove any lines for you from Sky and to install Plusnet lines for your connection. This is a necessary procedure.
With regards to the router, this will be dispatched as soon as the install engineers have completed the phone line installation. This is because they will confirm the line suitability, which will tell us what type of broadband can be supplied, and what type of router is required.
The router is automatically dispatched by First Class Royal Mail once the broadband request is placed, for delivery within 3-5 working days..
We will monitor to ensure the phone line is activated, and to place your broadband order."
Firstly, the bit about suitability and what type of broadband can be supplied, why is this not known now? Does this mean I might not get what I've ordered and paid for?
Secondly, I was under the impression from your information that everything would be done on the same day, if the router is only dispatched after you've taken over the line then surely I'm going to have no internet for probably a week?
Regards
Ian
Re: Fibre order
08-08-2018 11:55 AM
Apologies for any confusion and concern caused.
As we're having to install the phone line first before we can order broadband on the line, it's possible that fibre isn't available as we won't know 100% until the phone line is active.
That said there's a good chance it is available because searching your address Here indicate fibre is available however our suppliers advise that the most accurate searches are done by a telephone number(Which we don't have at the moment, so we're needing to install the phone line to determine that).
If in the unlikely event that fibre isn't available then we'd give you the option to cancel your order free of charge refunding your initial fee back to you, or take out a broadband package with us instead.
Apologies that this wasn't made clear to you that there would be two activation dates.
As we're installing a new line not taking over an existing line your service with your current provider should keep on working until our service is installed, which brings me on to my next point and possibly the most important...
The option you selected during the signup process was to specifically install a new line rather than to takeover the existing line. If this was incorrect then we're best off cancelling the new line installation and taking over the line as per Gaining Provider Led process where it'd take 10 working days and there would be minimal downtime in your service.
Let us know how you'd like to go ahead.
Re: Fibre order
08-08-2018 1:06 PM
Thanks for getting back to me.
As far as I'm aware I had no choice as to a new line or not. This in itself was confusing to me as I did not know why a new line was required, also if you look on the ticket I specifically asked what needed to be installed and if my existing service with sky would be cancelled by you taking over the line.
I would like to go ahead with you taking over my existing line if that is possible.
Regards
Ian
Re: Fibre order
08-08-2018 3:30 PM
Hi Ian.
It's a bit odd, I'm sorry if you weren't given an option to takeover your existing line upon signup.
I've looked into this and things appear to be a bit more complicated. I've replied to the ticket on your account with more detail.
Re: Fibre order
10-08-2018 7:35 AM
Have you previously been a Plusnet customer on the phone number you’ve asked to be taken over?
Re: Fibre order
10-08-2018 7:50 AM
No I got that number when I got sky.
The problem appears to be that I live in a flat and the myriad of different ways that different systems record that.
Re: Fibre order
10-08-2018 7:58 AM
If yes there is some possibly that it is not properly registered in BT’s systems.
Re: Fibre order
10-08-2018 8:50 AM
Re: Fibre order
10-08-2018 8:52 AM
Re: Fibre order
19-10-2018 9:52 AM
I'm still waiting for my refund following cancellation of my order, can this be chased please.
My original support question has been closed so had to post here.
Re: Fibre order
19-10-2018 1:57 PM
