due to switch providors 1st April 2020
kchambers
I was due to switch from plusnet to BT on 1st April 2020. This was because plusnet could not offer me fibre broadband in my area. I read in the media that BT are no longer making home visits although at the time of writing they have not contacted me to say this. My problem is that having informed plusnet of my termination date, I will be left with no broadband or landline connection on or after 1st April. I do not want to phone plusnet as I know that the lines will be very busy. Can someone, preferably from plusnet help clarify my situation. I am 75 years old and need both services at this critical time. thank you.
7 REPLIES 7
Fixes: 1,485
Re: due to switch providors 1st April 2020
Moderators Note
This topic has been moved from ADSL Broadband to My Account/ Billing
daveplus
Fixes: 10
When you switch ISP you should sign up to your new ISP who will then ensure the switch is carried out. If you have terminated with Plusnet then that may a problem
Dave
kchambers
I wanted to keep my plusnet email address and I phoned them to ask how to do it. They said I had to give them notification verbally over the phone of the change over date. Having done that plusnet would send me an email on 31st March confirming this. I would then have to phone them within 24 hours of the email being received so that they could re activate the email account. If it were not for wanting to keep my email address I would not have contacted plusnet at all before the change over date as I assumed that BT would have done this automatically. I think I have no option but to phone plusnet to clarify the situation.
daveplus
Fixes: 10
Fair enough
kchambers
Thanks anyway for taking the time to respond.
kchambers
Thanks, but not much help.
kchambers
last reply was to dvorak. plusnet mod.
