can't make changes
- My Account/Billing
- Re: can't make changes
can't make changes
09-08-2023 12:01 PM
Plusnet took over my landline recently, the transfer happened on 4 Aug 2023. I want to add (free) voicemail but when I log in I get:
An error has occurred
09-08-2023 12:19 PM - edited 09-08-2023 12:20 PM
@stuck wrote:
...it's just Plusnet's systems lagging behind reality and it needs a staff member (perhaps @willcutforth or @Gandalf ) to manually intervene?
Yes, it's long been one of Plusnet's speciality features, and will require manual intervention.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
09-08-2023 1:41 PM
Hi @stuck
It looks like there's a little bit of lag with updating your account in one of our systems.
The change is scheduled to complete on your next bill date, so that message should go away then.
Let me know if there are any further issues.
09-08-2023 4:47 PM
@Gandalf wrote:
...The change is scheduled to complete on your next bill date, so that message should go away then.
OK I'll wait until then (but it would nice to have the voicemail sooner than that).
09-08-2023 6:36 PM - edited 09-08-2023 6:37 PM
09-08-2023 9:57 PM
@Gandalf wrote:
...that would likely have caused complications...
OK, waiting sounds preferable to the alternative you set out.
09-09-2023 9:45 PM
@Gandalf I forgot to come back and say that, as you said, once my next bill went through, I was able to add the free voicemail option.
Thank you for explaining things.
27-09-2023 11:24 AM
@Gandalf Umm, today I find the same error message:
27-09-2023 11:35 AM
Moderators Note
This topic has been moved from Home Phone to My Account / Billing
27-09-2023 11:54 AM - edited 27-09-2023 11:57 AM
27-09-2023 12:02 PM
...stuck...
😃 I see what you did there.
Yes, all OK now. Thank you for the quick action!
27-09-2023 12:20 PM
