Total loss of mobile signal
FIXED- Subscribe to RSS Feed
- Mobile
- Total loss of mobile signal
Re: Total loss of mobile signal
23-12-2016 6:08 PM
@BullyBeef wrote:
Try this to find out where your number was originally issued to.
It you have had a problem over the past 24 hours the answer is probably brightly coloured!
https://www.mobilephonechecker.co.uk/guides/network-checker
Excellent, cheers. Just coming up to 17 years according to that which I wouldn't have guessed at anywhere near or is that when Orange reserved it?
23-12-2016 6:09 PM
@Philistine wrote:
Thanks once again BullyBeef. You are spot on with that link. My number issued Feb1999 to me! and this the first time I've changed mobile service provider!
PS Still not back on in Horsham.
Hmm, mine says Feb 1999 too, coincidence?
23-12-2016 6:14 PM
The date will be when the block of numbers were initially allocated by Ofcom to a mobile service provider. My number is from 1997.
The provider that the block of numbers were issued to then has a perpetual responsibility to hold the pointer records for that number so that the mobile networks know where to route calls and texts to.
Hope this helps.
23-12-2016 6:18 PM
Looks like Feb 1999 was the date when Orange reserved the number. I purchase a Nokia NK402 and a Just Talk Pack with my current (only) number in September 1999 from Carphone Warehouse
23-12-2016 6:21 PM - edited 23-12-2016 6:22 PM
Ahh, of course. I've just tried the one issued by PN to me and it comes back as Orange back in Nov 2009 so it must be a regurgitated number which makes that website less useful than it first seems.
23-12-2016 6:32 PM
Just been out and about and it looks like I spoke too soon about the service being back. Got voice and texts, but no mobile data (yet).
23-12-2016 6:48 PM
23-12-2016 6:53 PM
I don't think you can enter them manually on an iPhone can you?
23-12-2016 7:00 PM
Hi @silverage,
You can't enter the APN settings manually, however you can reset them which usually reconnects you to the correct network.
Go into Settings > General > Reset > Reset Network Settings.
Let me know if it works
23-12-2016 7:07 PM
Ok - I'm going in ....
23-12-2016 7:10 PM
Didn't work. Just got the signal strength blobs and "plusnet". No 3G or E for data.
23-12-2016 7:12 PM
23-12-2016 7:17 PM
Should my data have come back with my voice and texts or is it possible that it may come back later? I would have expected it all to come back at the same time really. Getting a bit tired of this now.
23-12-2016 7:19 PM
Perhaps you can still change them by accessing the following website via the iPhone in question on WiFi. I've not used them myself btw.
23-12-2016 7:23 PM
No signal for me yet...
My number was originally registered with vodafone, ported to EE, and then to Plusnet.
