Number ported, no mobile data network
- Mobile
- Number ported, no mobile data network
- « Previous
- 1
- 2
- Next »
Re: Number ported, no mobile data network
27-06-2018 12:15 PM
I don't seem to have a profiles section? Only have Itunes wi-fi sync and VPN?
27-06-2018 12:27 PM
What error message are you receiving when you try to access data?
- Rebeka
27-06-2018 1:53 PM
PDP Authentication failure
27-06-2018 2:16 PM
If you could please send me a Private Message WS, I can look into your account for you.
- Rebeka
27-06-2018 3:16 PM
My phone now appears to be ok, connected to plusnet 4G 🙂
My phone has been off and on over the last few hours as it was getting a repair done and after that it seems to be ok for data.
27-06-2018 3:17 PM
Hi gc6500,
That's great news!
If you need anything else, don't hesitate to get back in touch with us.
- Rebeka
27-06-2018 3:28 PM
Thanks Rebeka
27-06-2018 4:37 PM
Hi Rebeka,
I've done this. Please can this be addressed as soon as possible, I leave the country for a bit and need this resolving by tomorrow.
Thanks,
WS
27-06-2018 5:24 PM
Hi Rebeka,
It seems to now be working I re-set the whole thing again!
Thank you
WS
27-06-2018 7:06 PM
I'm in the same boat, no data since porting, in fact no data ever, but I did put the port request in as soon as I got my SIM.
Rebeka, I have you a PM to see if you can help ?
Thanks,
Mark
28-06-2018 9:48 AM
Hi Rebeka
I am also having this problem.
I have tried all the suggestions in this thread. Could you assist please ?
Adam
28-06-2018 3:37 PM
Tried to get my no data problem resolved over the phone, but all they could suggest was to send out another SIM card.
Hopefully it will fix it but I'm not getting my hopes up.
29-06-2018 8:03 AM
Hi everyone,
I have been away from the office, so unable to respond.
Can you please try another re-boot, ensuring that the SIM has been removed from the handset when doing so.
- Turn the handset off
- Remove the SIM
- Leave it for a couple of minutes
- Replace the SIM card
- Turn the handset back on again
thanks,
- Rebeka
29-06-2018 10:42 AM
Maybe the mods can split the thread off to people having a different (but the same) issue?
I would do what @RebekaPreston suggested then also try a soft reset on your device.
Depends on what you're using, but a quick internet search should tell you how.
Do not do a hard reset unless you have a backup of all your data.
- « Previous
- 1
- 2
- Next »
- Mobile
