No signal in Spain
- Mobile
- No signal in Spain
- « Previous
- 1
- 2
- Next »
Re: No signal in Spain
02-08-2020 11:29 AM
Hi
How is your phone now? I once again have nothing, no calls, no texts and no data.
The funny thing is have just changed to new plan and now get 8gb of data!! No, I am not getting anything. So very frustrating.
They say there are issues but they need to get this sorted, cannot keep paying for no service😕
02-08-2020 3:17 PM
Hi @Judi, thanks for getting back to me. I am sorry that the network XFERA is not listed as an option to connect to.
I will raise this further with our Ops Team but I won't have a response until tomorrow. In the meantime, could you send over a PM with a screenshot of the available networks you're seeing, advise of the area of Spain you are currently in and also a contact number I could reach you on (if you have one).
03-08-2020 4:01 PM
XFERA? Ditto.
but and I can't believe I'm doing their job for them again, XFERA is actually yoigo, so I guess it's worth a try on yoigo. Meanwhile, having exhausted all the standard options in the script, support have basically said they can't help!!
03-08-2020 5:49 PM
Can't understand why they can't help us out by just diverting calls to another number like my wife's virgin phone... they only need to change the Voicemail number on my account but won't do it
04-08-2020 11:00 AM
Because they don't care. Interestingly, when I asked for a porting code (online, easy) I immediately got an email trying to get me to stay. Sales is all they care about.
Worth noting however, that the email offered "special deals" only available to me (yeah right!) one of which was 3gb data, unlimited minutes and texts for 6 quid a month without a contract, or even more data with a contract.
05-08-2020 10:21 AM
They did switch off roaming and then back on, I then had a signal briefly.
Condescendingly asked me if I was enjoying my holiday! Even worse when I'm here to look after my very ill father and need to make and receive important phone calls.
At their suggestion I have paid for a PAYG SIM card but cannot use my bank accounts as they require phone authorisation.
When this debacle is over I will be changing my two phone accounts and broadband to another provider.
05-08-2020 11:27 AM
SO now customer support are literally ignoring me, no response to messages or emails!
Class action lawsuit anyone?
05-08-2020 11:43 AM
I would advise putting your mobile into manual selection mode and turn off auto.
Then try each network which it will pick up and find one which may work.
Years since I went there (how's my brain doing?), and it may have changed there now. I believe you (used to) have Airtel and Movistar.
05-08-2020 9:16 PM
Problems with plusnet when out of the UK are often reported, but rarely solved! Possibly the issue in Spain is the partner they’ve chosen I.e. Yoigo, if you don’t see that as a network, your phone probably won’t work. Yoigo theoretically have arrangements in place to use other networks when they don’t have coverage, but I don’t know what happens in the real world.
I’ve only been a Plusnet customer for a short while, can’t wait to get back and MOVE!
06-08-2020 6:37 AM
Still no data, whats going on?!!
very fed up 😞
06-08-2020 1:59 PM
Now I once again do not have any signal, no calls, no texts and def no data!!
Any suggestions?😞
06-08-2020 2:28 PM
Port your number to another carrier when back to the UK. I´ve been having the same issue for the past 2 weeks and no solution at all.
06-08-2020 3:06 PM
yep, just looking at options - virgin sim only £6 for 3gb or 8gb for £8 a month through uswitch
06-08-2020 3:10 PM
It appears the service has gone downhill since BT bought them out.
06-08-2020 3:15 PM
Two of the phones were always connected, the Plusnet one, only in a few areas where Yoigo exists. Trying to connect to other networks fails.
Remember, I’m in a popular tourist area in Mallorca, not in the middle of nowhere!
To my mind the ‘service?’ Is not fit for purpose, the roaming agreements which Yoigo claim to have with Movistar & Orange do not work in practice (only on Plusnet ?) Plusnet MUST know this, if I am wrong then please enlighten me!
WE WILL DO YOU !
Proud?
- « Previous
- 1
- 2
- Next »
