No Mobile Data
SteveA
No Mobile Data
Just put the SIM in the phone last night and it had a data signal at home.
Sitting here at work with a strong Phone Signal but the Mobile Data is "Disconnected"
If I do a search for all network operators  it shows Plusnet 3G and 4G. 3G has a coloured star next to it which I understand means "preferred" network, but it doesn't connect. Attempting to register on the Plusnet 4G leads to it hanging on "registering on Plusnet (4G)" before it failed with a message saying my SIM is not authorised to connect to the network.
I did start the port process last night so could it be due to that?
38 REPLIES 38
MichaelWilliams
Fixes: 15
Re: No Mobile Data
This is almost certainly down to the porting process
SteveA
Re: No Mobile Data
All Ported - Plusnet sim in phone, text messages coming over with the number I ported in but I am unable to get a data connection.
SteveA
Re: No Mobile Data
Still No data - Claims Sim not allowed to register on the network.
Not impressed ...
SteveA
Re: No Mobile Data
@MichaelWilliams - can someone look into this for me.
SteveA
Re: No Mobile Data
It looks like the APN settings never got set.
I've manually set them up following the details on https://www.plus.net/help/mobile/mobile-phone-and-voicemail-settings/
MichaelWilliams
Fixes: 15
Re: No Mobile Data
Apologies for the delay in my response,
Bramleyapple
Re: No Mobile Data
Michael,
I'm a first time poster, so bear with me.
I have just changed to Plusnet mobile. I have ported my number. My calls and texts work correctly but not data (on a 1.5gb data plan). I can open a personal hotspot and use data on another phone but not on the iPhone SE that the sim card is in. I've phoned your call centre several times and they suggested a few things (that didn't work) and eventually told me to telephone Apple.
I can't access the APN settings (it's not there).
Can you please help (I tried to private message you but couldn't get it to work).
Thanks,
Dave
SteveA
Re: No Mobile Data
I strangely didn't get a notification about your reply.
Yes it's all working fine now thanks
MichaelWilliams
Fixes: 15
Re: No Mobile Data
Hi Dave, you should be able to PM me now that you've made a post in public.
A 'network settings reset' should resolve this - this will erase all Wifi and data settings on your phone, and draw brand new data settings from the network. (Please be aware that this will remove any Wifi passwords and you'll have to re-enter them on your handset.)
To do this on the iPhone, please tap Settings > General > Reset > Reset Network Settings. Let me know how you get on Smiley
RobMuir
Re: No Mobile Data
I’m having this problem also (or my girlfriend is).
She switched over to Plusnet over a week ago. Her old number ported with a delay. Now she can’t access data without a WiFi connection. I contacted customer services, as did my girlfriend via online chat. I was told no Plusnet accounts are at our address - there are 2. Feel badly let down
MichaelWilliams
Fixes: 15
Re: No Mobile Data
I'm very sorry to hear this RobMuir. Please send me a PM with some account details and I'll get everything sorted for you.
RobMuir
Re: No Mobile Data
@MichaelWilliams I can’t seem seem to be able to send you a pm, we have tried customer services on another 2 occasions on the phone and been cut off 3 times by the online chat and still have no data or the ability to send text messages unless we have a WiFi signal.
Not impressed at all, we have been told we have a split port as even when we do call the number is not recognised.
Fixes: 385
Re: No Mobile Data
@RobMuir
Try again now, you need to have made more than 1 post before sending a PM is possible. You now have made 2 posts so you should be able to send one now.
RobMuir
Re: No Mobile Data
Thanks @MisterW now appears to work. Hopefully get things sorted soon, 3 weeks without data and texts has been far from ideal
