My mobile app is showing the incorrect data.
NoelMorgan21
Mobile app shows 4gb the website site shows 5gb
5gb is correct.
can someone have a look?
7 REPLIES 7
OskarPapa
Fixes: 65
Re: My mobile app is showing the incorrect data.
Hi @NoelMorgan21, thanks for your post.
Are you able to confirm whether or not the correct amount is displayed when logging in via the website?
NoelMorgan21
Yes the website is correct 5gb
Fixes: 1,601
Thanks for getting back to us @NoelMorgan21
Could you send me a PM with a screenshot showing the incorrect data you're seeing in the mobile app?
NoelMorgan21
Fixes: 1,601
Thanks @NoelMorgan21
Can you PM me your mobile number so I can investigate further?
Runmum78
Mine is the same!. I've just upgraded from 4gb to 7gb but my allowance says I have 4.6gb remaining when I had 3.97gb remaining yesterday! Not sure where my other 2.4gb has gone?
Fixes: 1,601
@Runmum78 Send me a PM with your full name confirming you’re the account holder, your full address and mobile number and I’d be happy to look into this for you. Smiley
