6in4 IPv6 Tunnel natively on Technicolor TG582n
- Trials
- IPv6 Trial
- 6in4 IPv6 Tunnel natively on Technicolor TG582n
Re: 6in4 IPv6 Tunnel natively on Technicolor TG582n
14-08-2012 10:41 AM
That said, a new versions is available and we are testing this. It's primary test purpose relates to Easy Setup, but will offer IPv6 still. We are hoping to make this available soon.
In regards to logs, I can only suggest logging the output of a telnet session to the router. Connect via Telnet and hit CTRL+Q to start console output. Provided it does spit out any needed errors before it reboots, this should make it available to you from your local machine.
14-08-2012 1:04 PM
I'm now capturing the output so let's see what that brings.
14-08-2012 3:56 PM
[quote=tg582n]
<37> Aug 14 15:17:26 LOGIN User Administrator logged in on [HTTP] (from 192.168.37.5)
<14> Aug 14 15:17:49 CONFIGURATION mbus atomic sync successful
[IGD-MBUS] igd1to1_getvalue_ds invalid value IP.Intf.6in4tunnel.LowerIntf='loop' (Invalid parameter value)
<14> Aug 14 15:17:50 CONFIGURATION failed to sync mbus igd
[config] configuration autosaved after delay
The only other time it's reset was when I had to reboot the PC and putty wasn't running, typical.
14-08-2012 4:37 PM
Quote from: Picnic Do PN make available a flash utility for the router?
The flashing utility for Windows users linked in the TG585v7/v8 library article here should also work with the TG582n reference ...
Quote from: P The process to flash a router is quite simple, though is only available to windows users. Instructions can be found here which is applicable to the TG582n as well.
14-08-2012 8:50 PM
I'm too clever for it so I've just swapped browsers to see if that helped. Chrome == reset reset, IE9 64bit == good download. Off to play now and see if I can flash it again.
15-08-2012 11:41 AM
That's not the version you're claiming is it? Seems to be 10.2.0.11.0.
Seems the tool also resets the router so flashing a new version may prove difficult
15-08-2012 2:24 PM
15-08-2012 3:06 PM
15-08-2012 4:20 PM
16-08-2012 9:13 AM
16-08-2012 12:22 PM
Tried:
user: Administrator
pw: access key
pw:
and pw : Administrator
with no luck.
16-08-2012 12:36 PM
16-08-2012 12:38 PM
16-08-2012 1:16 PM
Ex-Broadband Service Manager
16-08-2012 1:27 PM
