Plusnet SmartTalk?
mikealexander
Plusnet SmartTalk?
Any plans for Plusnet to provide something similar to BT SmartTalk for their Home Phone customers? Plusnet must have access to the same technology given BT owns them?
8 REPLIES 8
James
Re: Plusnet SmartTalk?
I don't think that we do have access to the technology.  It sounds a bit like BT Fusion from years back.
We don't currently have any plans for something along these lines.
I've downloaded the app.... just in case.
I don't even have an iPhone, or iPad ... yet
This page auto downloads to my iTunes, as do all apps
https://itunes.apple.com/gb/app/bt-smarttalk/id586965407?affId=1018132
But I do have an Android Smartphone
https://play.google.com/store/apps/details?id=com.bt.voiceapps.homeaway
http://www.hotukdeals.com/freebies/bt-smart-talk-make-phone-calls-from-your-mobile-pay-landline-pric...
Simon_M
Isn't this just a user-friendly version of VOIP, linked to your landline number instead of a dedicated VoIP number?
The Plusnet/Gradwell VoIP offering gives equivalent functionality, but it does require a bit more setting up & understanding.
Or have I missed something . . . . ?
Fixes: 396
and no incoming call facility
Fixes: 1,483
i guess BT had all the fusion stuff 'lying around' from the previous attempt which required a specific phone and managed to transform it into this, as James said.
For PN to do it they'd have to write a massive integration piece with Gradwell and for Gradewell to provide the service it would cost as well.
I quite like smart talk and will be using to reduce my mobile package price at renewal time in a month or so.
machare
Quote from: James
Is this still the case and is there any chance that it might change?
anniesboy
Isn't this like Viber for android?
machare
Not really. SmartTalk is a VOIP application that goes to BT and uses your BT landline call allowances/charge rates.
dick:quote
